VIN ???
Re: VIN ???
Postby Admin-bloke » Sat Apr 28, 2012 9:45 pm
It passed !
Ok, it failed first on the left hand indicator dashboard lamp not illuminating.
One replacement bulb later and I got the certificate.
Very Happy :D
Re: VIN ???
Postby mec » Sat Apr 28, 2012 10:46 pm
mine didnt :( :( :( :(
on the up side though this is the first year since ive owned it that the emmisions passed perfectly, guess who thats thanks too ;) :kiss:
Re: VIN ???
Postby Admin-bloke » Sun Apr 29, 2012 12:52 pm
mec wrote:mine didnt :( :( :( :(
Re: VIN ???
Postby Admin-bloke » Sat Jul 20, 2013 4:27 pm
I have not done much to my valuable "Mighty Auto" over the last couple of years (, too busy with work, my main daily driver cars and helping fellow D owners). However, after starting in may I removed the left hand manifold as it was chuffing chuffing like a train due to blown exhaust gaskets. After suffering with sheared and seized studs I finally got them all out of the left hand side.
After a prompt delivery from Delorean Europe (thanks Ed) supplying a full exhaust kit, I have finally redone the left hand exhaust after spending half a day in my hot humid garage pit. She is now all back together and running, although it's time to redo the valve clearances and reduce the primary fuel pressure and.........
Chuff me it's never ending !
Re: VIN ???
Postby lukebrynycz » Fri Aug 09, 2013 12:59 pm
But well worth it ;-)
lukebrynycz
Re: VIN ???
Postby Admin-bloke » Mon Jan 27, 2014 2:25 pm
Well due to bring snowed under at work I've done absolutely nothing to my car or had much of a social life so sorry for not being in touch with folk.
This should change now that I've now finally finished off a control system at an airport and a long list of legacy projects others started but I've had to finish.
The upshot is that I should be around more to enjoy what I do most I.e. fix Deloreans and have a laugh with friends on here.
Re: VIN ???
Postby jerzybondov » Mon Jan 27, 2014 5:59 pm
Great stuff AB! :D
Re: VIN ???
Postby RobvdVeer » Mon Jan 27, 2014 8:12 pm
At least you found time to work on the car! I hope it'll get better i. The future...
Rob
Re: VIN ???
Postby Admin-bloke » Sat Jul 05, 2014 6:31 pm
Well I thought I'd pull the cover off my d and have a check over before I go for a drive:
An honest engine :)
Re: VIN ???
Postby Admin-bloke » Sat Jul 05, 2014 6:36 pm
I'll just check the injectors as I'm in the mood
While I'm in there I'll do the spark plugs. ..
Distributor swap
vac pipes
clear out the valley. .....
Valve clearances.
What have I done! !!!!! I feel the (back) pain on the "Dan's 2nd Delorean" level. ......
What the chuff did I do this for? ?
