Postby ALEXAKOS » Mon Oct 14, 2013 4:25 pm
Dangermouse wrote:Wow, that cleaned up nicely!
The mighty power of OXI-action Dermot! :ugeek:
And 100 bar Max. Flow Rate : 350 l/h Max. of spraying water!!!! :clap:
On to the evening news...
And and submerged into my darker quarters.
The Garage and the workshop at the bench.
Painted the D's top with a special antitrust frame paint first layer. (Sorry No pics...forgot but will catch up the day after tomorrow)
Then placed the front upper arm bushings I got from Josh @ DPI..
Everybody was curious how I would go about this job?
Well... I supposed this is a first for everybody in here eh?
Looking good?
Now you'll get to see the arms after the sand blasting and power coating job. Not Stock colors but I love it.
How?
Ok. I just used my bench's clamp.
With a bit of lube and slowly working it into position. In the one side I covered the clamp's surface with a cardboard to avoid the "injury" of the bushing and on the other side I used a cylinder with a cloth to allow the metal side of the bushing to protrude.
But... WHERE IS THAT CYLINDER FROM?
It is none other than the front wheel's bearing Shel.
On to cleaning out the steering rack.
That too has been powder painted
Again a quick reminder of the past situation:
Upper arm
Upper arm
Steering rack
Postby Dan 6511 » Mon Oct 14, 2013 6:20 pm
Looking good. I remember doing those upper bushes when I did my car. How have you fixed them into the arms? I seem to remember the originals having a small weld tack to stop them rotating in the arm.
Postby Dan 6511 » Mon Oct 14, 2013 6:29 pm
This restoration thread has made me look back through a load of pics from when I had my Delorean. Making me want to get another one!! :shock: I recon its having a break from it for 2 years, had time for the glasses to become rose tinted again ;)
Postby Admin-bloke » Mon Oct 14, 2013 6:48 pm
Go on Dan, you need a challenge ;)
Postby ALEXAKOS » Mon Oct 14, 2013 6:59 pm
Dan 6457 wrote:Looking good. I remember doing those upper bushes when I did my car. How have you fixed them into the arms? I seem to remember the originals having a small weld tack to stop them rotating in the arm.
Very good point Dan! I was wondering if those would rotate after a while.
I will TIG spot weld those in 3 spots each just for Making sure!
Dan you are right! THIS IS GOOD FUN!
Sent from a mobile device. Please excuse typos etc
Postby ALEXAKOS » Wed Oct 16, 2013 12:42 pm
I know it's a cheezy thing to buy....
But hey, for $40 total shipped from Germany, its a shame to let it go to waste. Most of those cost over $150
Need s bit pampering... ;)
And since I will never be using this apart for the effect. (I don't even own any VHS tapes)
this one is not functioning and he sold it for parts.
Paid his shipping and saved it from becoming spares. Now it will live on a glorious life as a movie prop
Postby RobvdVeer » Thu Oct 17, 2013 11:12 am
Lol, that reminds me of my brick phone!
Postby ALEXAKOS » Thu Oct 17, 2013 1:13 pm
RobvdVeer wrote:Lol, that reminds me of my brick phone!
Sounds dangerous! :lol:
I bet today's airline policies would forbid taking it aboard. :dance:
Can't really call it a full day's job cause I only worked for a couple of hours on my steering rack replacing the two friction parts
Right, here are the originals next to the copies I made with poly.
Right the melted filler cap knob left my replacement
Goes like this:
Then the centering cylinder that was ripped.
Left the original, right my poly repro
notice how large the gaps are on the original. I believe the main reason is minimal friction cause it was made of hard rubber
fitting
I rounded up the sharp corners
Postby ALEXAKOS » Fri Oct 18, 2013 4:11 pm
the time has come where the word "disassembly" moved on to repair and is now replaced by "reassembly"..
I present you the 2nd and 3 complete part of 5992
The steering rack
Refurbished inside out as you saw before. Sitting with brand new rod tie ends from our favorite eurotech store (thanx for a great service lads)
and the water pump
Cleaned from the hellish goo that sat in there. Then replaced all gaskets and seals.
Postby RobvdVeer » Fri Oct 18, 2013 4:22 pm
Wow. This is not reassembly, this is refabrication.
