Postby ALEXAKOS » Fri Feb 28, 2014 8:45 pm
After countless hours of cleaning, cutting, patching welding smoothing out and painting the frame is finally done!!!!
Images posted with before and after :)
Image[/URL]
Patched sides with new metal
Engine bay
Centre
And front
Time to get this baby back together again;)
Postby mec » Fri Feb 28, 2014 10:12 pm
Awsome !!
what paint did you use ?
Postby ALEXAKOS » Sat Mar 01, 2014 1:10 am
Special frame paint with anti corrosion shield. That paint would even grasp on a rusty surface. Kinda like those hammerite paints. But this is especially for frames to withstand high temperatures.
Postby ALEXAKOS » Thu Mar 06, 2014 5:20 pm
Started adding components onto the frame.
Camera is back working again so no more Iphone photos:)
Here are some better looking images of the finished frame:
First was the Gearbox shifting linkage
bars were powder coated mat black
and stick
Next were the brake lines.
I had them redone and added a transparent silicone tubing to help me bend them without snapping, Plus it adds protection from corners and rubbing against the frame.
Going out to the rear
Front T connection
Front complete and got to put the steering rack back in place.... Buy what a task...:dead:
Postby RobvdVeer » Thu Mar 06, 2014 7:44 pm
We need a Like Button quickly.
Rob
Postby ALEXAKOS » Thu Mar 06, 2014 8:03 pm
will this do?
Postby ALEXAKOS » Sat Mar 08, 2014 6:37 pm
Couple more steps achieved...
Cleaned my radiator and fixed a couple broken bolts.
Another cross used part from a European car.... But I guess ya'll knew that already....
Finished installing the steering rack.... What a pain to get it back in! Took me over 3 hours to get the bushings in place...
The radius arm masterpiece.
Black powder coated radius
DPI Poly bushing with special poly grease
DPI Tab
Stainless mounting bolts
Stainless brake lines
Complete rear system with SPAX shocks. New bushings and all black powder coated.
I know you fellas prefer the radius arm stock gray, But I preferred the powder coated solutions and the black color matching the rest of the set up keeping the X frame at its unique gray.
Pipes in red.. Just loved that touch!
Wait to see the coolant piping:)
Postby ALEXAKOS » Sun Mar 09, 2014 6:37 pm
Continued for an hour what I left off yesterday.
all piping in place
Both radiators refurbished
pimped up the Y pipe in he VOD. Yes it's blue like the crystal waters of the Greek oceans! :p
Actually all cooling pipings are going to be blue. Feng Sui to keep the Delo cooled in the Greek summers
Finally dragged the tranny onto the operating table to check that 2nd gear pin as well as change all gaskets, o-rings and seals
Postby ALEXAKOS » Mon Mar 10, 2014 8:14 pm
a couple of hours work, mounted the calipers after refurbishing them with handbrake assy and pads.
They are next to be placed on the frame.
and I drove my refurbished rims to put the tires back on.
Bling bling!
Postby Admin-bloke » Mon Mar 10, 2014 8:43 pm
How thick are those pads Αλεχακοσ? ;)
