Postby RobvdVeer » Sat Jun 07, 2014 8:21 pm
One window regulator done. Smooth as a polished bowling lane. :thumbsup:
http://www.youtube.com/watch?v=jhhdflha1T0
Postby MikeWard » Sat Jun 07, 2014 8:56 pm
Looking (and sounding) good there Rob, nice work,
Postby RobvdVeer » Sat Jun 07, 2014 9:12 pm
thanks mike, means a lot to me.
Postby ALEXAKOS » Sun Jun 08, 2014 7:24 am
nice:) So how did you get the motor to working?
Postby RobvdVeer » Sun Jun 08, 2014 7:57 am
ALEXAKOS wrote:nice:) So how did you get the motor to working?
Perhaps you missed the fact that I replaced the entire window regulator assembly? I also wrote I found a set of connectors in my cabinet, I stripped and recrimped the connector from the motor.
Postby ALEXAKOS » Sun Jun 08, 2014 9:01 am
Oops! Yeah I forgot about that your dad found the replacement. Sorry! Yeah I remember the connectors part;)
Postby RobvdVeer » Sun Jun 08, 2014 9:03 am
raki? ouzo?
Postby RobvdVeer » Sun Jun 08, 2014 6:06 pm
today was moderately successful.
after the initial joy of finishing up the drivers door i started on the passenger side. All went well until i had to assemble everything inside the door. Nothing bad happened, but it took me surprisingly much effort to get it together. Anyway job done, window down window up, down, clack, window off track. crap. now i have to get the drop window all disconnect again, bloody annoying. perhaps tomorrow will be better.
Postby ALEXAKOS » Sun Jun 08, 2014 8:08 pm
RobvdVeer wrote: it took me surprisingly much effort to get it together.
Took me 6 hours to swap door shells. Fortunately no injuries ad it is one of the common issues working inside those door wells :hand:
That is 6 hours without putting on the fixed glass. Still need a rubber fin :mrgreen:
So why did the window pop out? Did it goo to low into the door or were your guides not aligned correctly? Just asking in case I should expecting a common issue. :pray:
Postby RobvdVeer » Sun Jun 08, 2014 8:54 pm
ALEXAKOS wrote:So why did the window pop out? Did it goo to low into the door or were your guides not aligned correctly? Just asking in case I should expecting a common issue. :pray:
my guess : the bolted anchor point halfway the runner of the regulator is not sitting where it is supposed to be sitting, therefore it pulls the windows sideways (towards the front) when it shouldn't. tomorrow i'm loosening those bolts that fix the motor and try running it again. i will then lower the window and tighten the bolts at that position. because when the window moves upwards, the runner will get more room to play so to speak. :geek:
