I have this custom gauge lighting, called ElGlo or Indiglo or whatever from SpeetHut. EL sheet is a plastic sheet that lights up if you put 12V AC on it. It does not get warm and takes very little Amps. And it looks cool.
Today I broke the panel connector. It is fucked. The panel is internally damaged and doesn't work any more. EL sheet is non-reparable. Even worse is that the glue underneath basically wrecked up the original instruments. And of course, SpeedHut stopped making these for the DeLorean about 2 years ago. So I have 4 options:
- IMG_0811.jpg (1.34 MiB) Viewed 3770 times
- repair the gauge fronts. Close to impossible for me.
- repair the EL sheet, needs investigating.
- replace the gauge with new originals. $$$$$$$ = no.
- let it be.
Clearly option 2 is the way to go. I decided to buy new panels from EBay. I can separate the SpeedHut silkscreen pretty easily from the EL panel and cut the new ones to size. For $20 I have order on A5 sheet of blue EL that is more than sufficient for my broken panel. This leaves me some stuff for experimenting or other fuck-up's.
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 1480809111I love ebay
