It was so intense I could barely open a door!
Some medication brought it back to life and started doing a few simple things
So I worked on the impact absorbers back and forth.
First cleaned them out form corrosion.
Repaired and applied some spray on vinyl underbody coating.
Both ends trying to keep the four fish cave painting:)
Next up I started to regrain the T panel on the roof. Used a 120 sand paper Aluminum oxide ofcourse, and with gentle straight motions (with my left hand) I got that fresh feel back on it.
To be softer on the edges, I rolled the sand paper on a 1 inch thick sand sponge
This is what I had to work with
and a few scratches here and there
On the left you see the finished sample.. The right is undone
Getting somewhere....
[/quote]
