CPR
Re: CPR
Postby Horsebox » Thu Aug 21, 2014 10:33 pm
delorean12uk wrote:I have a varied range of control pressure regulators, The one that was mounted on the Delorean engine had vacuum ports for forced induction applications and also emission control applications. I don't know whether you are running Delorean or Volvo fuel injection, if the latter you just need the basic CPR, I have few kicking about £40 posted if your interested, I might have a Delorean one as well, will have to check
I don't know whether I have Delorean or Volvo fuel bits. My CPR serial ends in 066 and the fuel distributor ends in 109 if that helps. Other than that there seems to be one vacuum port to the CPR that is just vented to outside air...
Best wishes,
Mark
Horsebox
VIN #: 06042
Re: CPR
Postby Horsebox » Fri Aug 22, 2014 12:00 pm
I just pulled it off the car and this is what it looks like....
Horsebox
VIN #: 06042
Re: CPR
Postby Admin-bloke » Fri Aug 22, 2014 4:45 pm
For £40 it's probably just as cheap for you to swap one for one of Jays. Don't throw your original one out add I might be able to make a good one out of a few duff ones to act as a known spare to help others.
Re: CPR
Postby delorean12uk » Fri Aug 22, 2014 4:57 pm
Horsebox wrote:I just pulled it off the car and this is what it looks like....
that looks clogged to me, have you got an air line and clean it out???? there not that hard to strip down and clean
Re: CPR
Postby A Van » Sat Aug 23, 2014 6:40 pm
That looks like it wants a clean, I thought I had a spare I could lend you to at least try but no I have some fuelling stuff but it's all old an needs refurb
Re: CPR
Postby Horsebox » Sat Aug 23, 2014 7:03 pm
Thanks for the kind offer. I've put the regulator in the post to for Ken Mills to work some magic on it...
I'll have to get at the fuel tank in the interim to make sure it's not going to get recontaminated when it's plugged back in.
Cheers,
Mark
Horsebox
VIN #: 06042
Re: CPR
Postby A Van » Sat Aug 23, 2014 7:12 pm
Take a look at your fuel filter as well, maybe worth changing
Tom2 has a spare CPR from a DeLorean which he says you can borrow if need to check
