Postby RobvdVeer » Fri Sep 26, 2014 4:25 pm
place
first fuel since 3 years
'le moi' doing the parking.
park
Postby jerzybondov » Fri Sep 26, 2014 4:52 pm
Great stuff Rob! Must feel fab to have her back...
Postby RobvdVeer » Fri Sep 26, 2014 5:01 pm
Thanks Gez,
Yes it is good to have her working, running and mot'd. Ed particularly noted the bad condition of the TABs that he replaced. They were bent, rusted and stuck. He had to grind them off to get 'em out, "A serious security risk" he said. Next to that he:
- installed front end recall plates
- replaced windscreen
- replaced a/c dryer and orifice tube
- reinstalled exhaust studs and gaske
- fixed exhaust tips
- replaced oil filter and j-junction
- aligned RH door
- new TAB bushings
- replaced rear flexi brakes hoses (now yellow all around)
Postby RobvdVeer » Fri Sep 26, 2014 6:53 pm
i forgot to mention i'll be needing 6 new injectors. I'm on Ed's list for those.
Postby ALEXAKOS » Fri Sep 26, 2014 7:31 pm
Your D looks real clean Rob.
What engine is in the d on that first picture???
What's with your injectors?
Postby RobvdVeer » Fri Sep 26, 2014 7:33 pm
Ed has a 24v renault engine for a client, you mean that one?
My injectors are just bad and aged because of low usage. Rust has formed and cleaning them won't help in the long run.
Postby Admin-bloke » Fri Sep 26, 2014 9:38 pm
RobvdVeer wrote:Ed has a 24v renault engine for a client, you mean that one?
I'll have a go at cleaning them Rob. I've done one or two.
Your car is looking great by the way :thumbsup:
Postby BABIS » Sat Sep 27, 2014 12:22 am
nice pictures! just for curiosity, does Ed perform all the works by himself or does he have other mechanics in the shop?
BABIS
Postby RobvdVeer » Sat Sep 27, 2014 9:51 pm
When the season is over i might take them out, so you can have a go.
Postby ALEXAKOS » Sun Sep 28, 2014 7:34 am
This is such a greatly sported forum with lads such as AB ready to lend a hand anytime! :)
Rob, dono. I saw a read badass engine in the first pic where and is welding an exhaust...or so it seems
