Postby RobvdVeer » Wed Oct 01, 2014 10:17 am
Hey it is starting to look like a car you should be proud of that!
Postby ALEXAKOS » Wed Oct 01, 2014 10:36 am
RobvdVeer wrote:Hey it is starting to look like a car you should be proud of that!
Like a car? Eeeeekklkk!! :s
I'll be proud if it starts looking long a new Delorean;)
Thank u Rob;)
Postby A Van » Wed Oct 01, 2014 11:31 am
Looks good keep going!
Postby ALEXAKOS » Wed Oct 01, 2014 12:09 pm
A Van wrote:Looks good keep going!
that is the only way;)
Postby ALEXAKOS » Wed Oct 01, 2014 7:15 pm
Whoohaaa!
Just purchased a set of Renault alpine A610 turbo exhaust manifolds with heat shield for just 30€.
Gonna make my own exhaust system...
Postby RobvdVeer » Wed Oct 01, 2014 7:32 pm
showoff!
Postby ALEXAKOS » Wed Oct 01, 2014 7:35 pm
RobvdVeer wrote:showoff!
Right on! Ha!
Postby ALEXAKOS » Fri Oct 03, 2014 6:49 am
Anybody ever removed the water pump knows what those hieroglyphics stand for....
This time I covered the VOD so I don't have to collect the coolant from all the little wholes...
And the coolant ran into a container in the front
On opening the pump, the gasket was tightly glued still in the lips and came apart splitting in half.
Looking closer I realized it was the gasket its self that failed. The slight leakage derived from a slight spot where the gasket probably had come apart. Note this was a brand new gasket....
Notice the wet area of the gasket and the rest is dry.
On assembly I chose to just use gasket silicone that is special for coolant components.
Back on the engine with this the rascal...
If that pump fails again.... I'll get a complete new engine before I think of removing it again.... :s
Postby RobvdVeer » Fri Oct 03, 2014 7:16 am
What doesnt kill you makes you stronger?
Postby ALEXAKOS » Fri Oct 03, 2014 7:20 am
RobvdVeer wrote:What doesnt kill you makes you stronger?
You're the only person to know exactly what it means Rob;) cheers!
You should be a step before turning into superman:)
Heck I saw the video when you cleaned your garage at warp speed. Heheh
