Postby RobvdVeer » Fri Oct 03, 2014 7:26 am
If only....
"...what doesn't kill you..."
No, being struck by cancer i say from experience that line is total bullshit.
Postby ALEXAKOS » Fri Oct 03, 2014 7:35 am
RobvdVeer wrote:If only....
I can only imagine....:(
Postby ALEXAKOS » Fri Oct 03, 2014 9:40 am
A proud moment, slash, nice photo....
Refurbished and regained the front emblem
Postby ALEXAKOS » Sat Oct 04, 2014 6:44 pm
Finished installing my new headlights with angel eyes or halo which ever you prefer.
So I hooked it up with my new battery and these are the first signs of life I got.
A lit empty tank which kept illuminating even when I pulled out he key. Note I have a special auto sender unit.... Here that light is not supposed to work
when I hit the light switch things got nicer
The instrument cluster fully with LED.
Side marker LED
And the halo headlights... With HID bulbs
The halo get the power from the marker lights while the HID get power straight from the battery having an in between relay give the command over the stock switch.
Postby A Van » Sat Oct 04, 2014 10:35 pm
Nice lights , what tank sender do you have then?
Postby ALEXAKOS » Sat Oct 04, 2014 10:40 pm
A Van wrote:Nice lights , what tank sender do you have then?
a stainless steel release of special auto
Postby Dan 6511 » Sat Oct 04, 2014 11:09 pm
Is that a John Hervey sender?
Postby ALEXAKOS » Sat Oct 04, 2014 11:37 pm
Dan 6511 wrote:Is that a John Hervey sender?
John Hervey, Michael Jackson, Alec Baldwin... Whatever he is called no clue..
It's this one
Postby ALEXAKOS » Tue Oct 07, 2014 3:25 pm
unLEDaded?
Not my Delorean :)
Tried my LEDs on my read lights and they were getting a lazy light out. Some were even shimmering like stars...
Time to refurbish those tail lights and revive the circuit boards
First drilled tiny holes right over the point the harness connector clips on
Then welded the wire edges onto the corresponding connection..
Wiring for the rear
the end effect....
Full blast clean light
Stop
Tail light
and reverse
Postby RobvdVeer » Tue Oct 07, 2014 3:34 pm
Good job. Easily saves you €100 this way.
