LH Rocker Cover
LH Rocker Cover
Postby carl hammond » Wed Oct 08, 2014 12:09 pm
Does anyone have a spare left hand rocker cover gasket pretty please? Discovered my one has started to come away and is leaking.
Many thanks :)
EDIT: Looks like I might be able to get just one from here: http://www.ebay.co.uk/itm/120457060814 I don't need a whole set, so if anyone does have a spare, give me a shout.
Cheers!
Re: LH Rocker Cover
Postby arranj » Wed Oct 08, 2014 12:25 pm
If you phone them Carl they will supply just the one you want.
Re: LH Rocker Cover
Postby carl hammond » Wed Oct 08, 2014 1:57 pm
I tried them Arran, but they said they couldn't supply that gasket alone. Anyone?
Re: LH Rocker Cover
Postby Dan 6511 » Wed Oct 08, 2014 3:18 pm
Might be easier to get a sheet of gasket paper and make one up.
Re: LH Rocker Cover
Postby BABIS » Wed Oct 08, 2014 3:35 pm
BABIS
Re: LH Rocker Cover
Postby Admin-bloke » Wed Oct 08, 2014 7:30 pm
If you can wait till euro tec October I'll bring you one. Bring some hylomar gasket sealant and you might get it fitted in exchange for beer...
Re: LH Rocker Cover
Postby carl hammond » Thu Oct 09, 2014 11:06 am
Thank you Mr. AB, that is very generous of you and of course I will pay you with beer in kind as well as source you a replacement gasket. :kiss:
I'll pickup some sealant, anything else I need at all? Speaking to TT about this, he said the best thing to do is disconnect the A/C Compressor and cable tie it, instead of removing completely to get better access.
Many thanks :)
Re: LH Rocker Cover
Postby Admin-bloke » Thu Oct 09, 2014 11:16 am
Yes the air con compressor is just unbolted and then laid over the inlet manifold without disconnecting the ac hoses
Re: LH Rocker Cover
Postby Admin-bloke » Thu Oct 09, 2014 11:19 am
Get some wd40 and give all visible bolt heads a spray every day from now on to make sure it all comes undone easily. Include the bolts of the pulleys to engine block and the belt adjuster at the left side of the engine
Re: LH Rocker Cover
Postby carl hammond » Thu Oct 09, 2014 11:25 am
No problem, I'll get lubricating today! :D
Thanks again.
Users browsing this forum: No registered users and 38 guests
