Postby Admin-bloke » Wed Oct 08, 2014 7:23 pm
RobvdVeer wrote:At least the documentation will match the car then.
That single sentence had brought a year to my eye (with happiness). :dance:
Postby RobvdVeer » Wed Oct 08, 2014 7:36 pm
Here's an example of how to extend wires, according to the PO:
- When replacing or extending a PURPLE wire, use a red one.
- When replacing or extending a BROWN wire, use a black one.
- When replacing a RED wire, use a brown one.
- If you have a perfectly matching connector, use a different one.
- Use isolation tape to make sure a twisted wire doesn't come undone.
- In case you don't have isolation tape of a disputable quality, use scotch locks in the most awkward position, preferable extremely closed to a terminal.
- When replacing a relay with a bridge wire, swap the pins around.
- Never use a crimp tool or heat shrink.
These rules are followed religiously. At least you know what you're dealing with.
Postby Admin-bloke » Wed Oct 08, 2014 7:51 pm
That last post sounds all too familiar. ...
Postby RobvdVeer » Wed Oct 08, 2014 8:26 pm
I scanned my car once more, there should be no more scotch locks remaining. I feel very proud about that. And tomorrow the fuse compartment will be much cleaner by removing all the nonsense wiring coming from and to the ac panel resistor. I will finish up that job this winter,when i will tackle the fusebox replacement and replace the wiring with the proper colors.
Postby A Van » Wed Oct 08, 2014 9:19 pm
Well done Rob
Postby RobvdVeer » Wed Oct 08, 2014 9:22 pm
A Van wrote:Well done Rob
Thanks. It really was one of the last gremlins in the electrical system. :text-imnewhere:
Postby RobvdVeer » Fri Oct 24, 2014 9:05 pm
Winterjob:
Fuel lines (bandit) and injectors (AB and mec)
Postby bandit » Fri Oct 24, 2014 9:30 pm
Nice one Rob.
Postby Admin-bloke » Fri Oct 24, 2014 10:13 pm
That was a quick delivery :D
Postby RobvdVeer » Fri Oct 24, 2014 10:47 pm
Sure was!
