Postby ALEXAKOS » Tue Oct 21, 2014 7:51 pm
Installed the t panel aligned it.
Fitted the Renault alpine spark plugs and set up the engine intake and fuel components ( for the 4th time)
Postby RobvdVeer » Tue Oct 21, 2014 7:55 pm
Terrible.
I mean awesome.
Postby ALEXAKOS » Thu Oct 23, 2014 5:08 pm
Hmmm, connected battery,...
Door ajar lights illuminate, lights switch turn all lights on.... That's it!
None of the key functions is working. As if the key lock or harness is not giving commands to either Acc or ignition, starter etc...
Postby Admin-bloke » Thu Oct 23, 2014 5:23 pm
You really have some wiring issues. ....
main ones:
Battery negative lead goes through body tub to the chassis. Check all earth points of wiring loom connect to the battery.
The connections to the chassis and from chassis to engine at the rear must have a good electrical connection. If you have painted your engine, you must clean the flex cable connection back to bare metal. ..
Postby ALEXAKOS » Thu Oct 23, 2014 5:27 pm
Would the lights go on if I had battery / frame ground issues? I'll check the engine
Could there be a main relay or fuse that keeps it dead?
Edit;
Grounding is fine. Put one end on the alternator + brown wire, and tapped the engine on various places. Seems the color does not insulate at all;)
Postby ALEXAKOS » Thu Oct 23, 2014 5:35 pm
I have not yet grounded the front harness. But I doubt that would keep the whole system dead:s
Postby RobvdVeer » Thu Oct 23, 2014 5:53 pm
I'm not sure if can help you with this, but checking the ground point for the instrument panel/cluster is what comes to mind. So I grabbed these from DMCTalk:
Postby ALEXAKOS » Thu Oct 23, 2014 6:01 pm
Thank you rob! Yes I see the front harness ground points are mentioned too. Maybe I need to set those up and o from there;)
Postby ALEXAKOS » Thu Oct 23, 2014 6:24 pm
On a happier note, I puts some juice onto my fuel pump.. Apparently it works fine..... And I heard flushing :(
One of the accumulator hoses was loose gushing fuel. One good thing delorean did was this peep hole index the centre console.. Pulled one screw and the cap.. Peek a booo!
Tightened that sucker. Repo we're the pump... And I heard it like blood in its veins running through after 25 years....
Here is a vid I made trying to spot any leaks.
http://www.youtube.com/watch?v=pA7zr35EyYQ
What sounded weird is after turning it off it made noises like the pipes were relaxing after the tension.
Postby Admin-bloke » Thu Oct 23, 2014 6:59 pm
Looking at the wiring diagram. There are 2 main big relays in the relay compartment tucked under the metal case.
One is for accessories and is energised when the ignition key is in position 1
the other is the main relay and is energised when the ignition key is in position 2
