Postby ALEXAKOS » Fri Oct 31, 2014 8:29 pm
Dan 6511 wrote:If your running volvo gear then you dont need the oxygen sensor or the fuel computer. You can get rid of it all :D
I aware of the sensor but which is the fuel computer?
Postby Dan 6511 » Fri Oct 31, 2014 8:47 pm
The big silver box inside the compartment behind the drivers seat. Has a big multi-pin plug going into it. Leaving it there won't do any harm though, its just redundant with volvo gear.
Postby ALEXAKOS » Fri Oct 31, 2014 8:49 pm
Oh the ecu! Damn it. And my d was missing it and I bought one. Hahaha.
Postby Admin-bloke » Fri Oct 31, 2014 8:50 pm
ALEXAKOS wrote:Thank Dan. I was going to test one when I received ab's advice too late. The Allen bolt to far right turned fell inside and I am having a great time trying to screw it back on:(
Btw you think the ecu not getting any feedback from the oxygen sensor kills the fuel? Although I had fuel literally tripping out my exhaust manifold:p
To be fair, your post was at 1:10pm and I answered at 1:14pm. Reap it real !!
Follow my original posted link as this will literally get you started from a known state, otherwise you will go around in circles, if not then I won't be able to help you further. .
Postby ALEXAKOS » Fri Oct 31, 2014 8:55 pm
Know ab. You were fast but j had already gone to far before. When it tried to screw it counter clockwise it fell in:(
I still have question.
Jason told me the only vacuum line I need is the one from the intake manifold to the distributor. I did notice a vacuum lead on my cpr but I lack an extra exit on the intake.
Is the cpr vacuum crucial on the Volvo config?
Postby Admin-bloke » Fri Oct 31, 2014 8:58 pm
Follow my original posted link. Remove the vac lines to the cpr first. ...
Postby ALEXAKOS » Sat Nov 01, 2014 2:15 pm
Update.
After a Long task of removing the Head and reinstalling it all up with a couple of efforts, I got the engine to last about 5 seconds but shaking. Touched both exaust manifolds. Cylinders 123 work, 456 don't. Fuel is sprayed but no firing going on I guess on that side.
Edit.. Scratch that... I am getting some action slowly.
Postby ALEXAKOS » Sat Nov 01, 2014 2:31 pm
What now???
http://youtu.be/fBBcugqvCz0
Get out some sausages and barbecue?
Postby ALEXAKOS » Sat Nov 01, 2014 2:54 pm
Okay... Got it working very roughly. Idle speed is going up and down.
http://youtu.be/5cVSGlyEhaE
Postby RobvdVeer » Sat Nov 01, 2014 3:39 pm
it sounds like a tractor, lol. But hey, it's running!
