HUGE store of parts here NOW in the UK for next day delivery
Re: HUGE store of parts here NOW in the UK for next day deli
Postby RobvdVeer » Sun Mar 08, 2015 5:39 pm
you are overexagurating the possibilities of my 3d printer.
Postby arranj » Thu Mar 19, 2015 4:56 pm
In case you missed the earlier posts, just to clarify that all parts are now on http://www.deloreanclub.uk
Previous links that put "buy now" buttons in the forum, along with regular forum updates about parts sales have now been replaced completely with this online shop.
Every single part we have in stock is now listed on there, with live stock levels. Everything is sent worldwide, with shipping prices being automatically calculated based on weight, size and destination. If it isn't on the website then the club doesn't have it in stock - if it is then we do :)
The parts shop has all the features you'd expect from a top-end shop, if you create an account it will remember all of your orders, there is a wishlist system, you can be notified when something out of stock comes back in stock, and much more. More features will be added if and when they are needed.
Recently we've had a large top-up delivery from Ed, with all parts listed now. To see just the parts that we have sourced via Ed just click on the relevant link on the menu ("View all parts sourced from DeLorean Europe").
In all cases the price is about 1%-2% cheaper than buying from Ed using a credit/debit card, plus of course the shipping price is considerably cheaper, and items are delivered a lot faster in the UK/Ireland.
Postby delorean12uk » Thu Mar 19, 2015 5:14 pm
Impressive parts store Arran!!! Clever sod!!!
Postby RobvdVeer » Thu Mar 19, 2015 5:23 pm
Congratulations, the site looks awesome! :D
Postby Dan 6511 » Thu Mar 19, 2015 9:07 pm
Blimey what an impressive website. Dunno how you do it Arran!
Postby A Van » Thu Mar 19, 2015 9:10 pm
Hard work
Postby arranj » Thu Mar 19, 2015 9:12 pm
A Van wrote:Hard work
Yep lol.
Bear in mind this (websites) is what I do day-in-day-out, so it's a bit easier for me. It does take a fair bit of time though!
Postby RobvdVeer » Thu Mar 19, 2015 9:32 pm
Can you fix the PostNL tracking and tracing site please? It is broken.
On the topic of 'this is what I do', would you be interested in an off-site free lance developer?
Postby arranj » Wed May 20, 2015 7:20 pm
A set of DMC-EU inner door seals now available from stock: http://www.deloreanclub.uk/inner-door-s ... -door.html
Postby arranj » Mon Jun 15, 2015 10:53 pm
Have taken delivery of a significant amount of parts again, this time the biggest yet. This is going to take a while to get listed up on the shop site, but basically near enough everything that was out of stock on there is now back in stock, and in addition we have 70 new parts in stock as well:
Suspension bushing 100154 x 10
Front end recall plates stainless (PAIR) 111141 x 4
Horn - high note 100466 x 2
Horn - low note 100465 x 2
Silicone hose kit K118674 x 3
Angle Drive 106130 x 5
Window Motor Kit 110073 x 5
Lock Set K110416 x 2
rear springs pair 100414PP x 2
Thermotime Switch 102125 x 10
Intake o-ring kit K111171 x 2
Injector Seals 102631 x 24
Exterior screw kit K100791 x 3
On off switch 111638 x 4
Rubber Exhaust mounts 105148 x 6
Door Strap Black, no ring 110308 x 2
Door Strap Grey, no ring 110309 x 2
Pulley Bearings 105638 x 4
Socket 106429 x 4
Crossgate Cable 101363 x 10
Support Buffer 108720 x 3
Support Buffer 108721 x 3
Escutcheon 101888 x 10
heater core 101271 x 1
Spring Latch sp10333 x 20
Stop lamp switch 100820 x 3
Luggage net 101454 x 3
Switch 101629 x 10
Bush 108151 x 2
Bush 105843 x 2
Mount Kit K100778 x 1
Gearbox mount 100901 x 2
Ignition Switch (sold already) 106679 x 1
Mirror Switch 105085p x 2
Reservoir Cap 105954 x 3
ARB Bushes 108912PU x 1
Fill Hose (used) 101562 x 1
Rubbing Strips (full set) (sold already) K114109 x 1
Valance (sold already) 100703 x 1
Valance (sold already) 100704 x 1
Valance Bracket 108080 x 1
Valance Bracket 108081 x 1
Steering Shaft (sold already) 100840 x 1
Rear number plate light lens 100438 x 4
Tail light harness connectors 101992 x 10
Oil sender (gauge) 102763 x 5
Rear defroster switch 101638 x 4
Lip seal 103049 x 3
Fascia Bracket 108466 x 2
Support Ring (stainless / new) 101644 x 8
Hood bump stop set 110186SS x 2
Headlight finisher 101602SS x 3
Water hose (sold already) 108676 x 1
Steering Rack (sold already) 108754 x 1
Relay (sold already) 105525 x 1
Relay (sold already) 100817 x 1
Pump kit (sold already) 107000 x 1
Hot water Valve 100763 x 10
Water hose (1 sold) 108675 x 1
Bosch Oil Filter 102114B x 6
Water hose 102153 x 4
Water hose 108679 x 2
shifter boot stainless bracket 100688 x 2
Front End Recall Full Kit K109269 x 2
Front light switch (sold already) 108388n x 1
hazard switch (sold already) 105660 x 1
brake hose set 100460/100459 100459 x 10
thermostat housing 102140 x 3
Thermostat 102709 x 5
Thermostat seal 102156 x 5
Users browsing this forum: No registered users and 63 guests
