Replica DeLorean Dealership Sign
Postby mknowlton » Sun Sep 13, 2015 9:17 pm
I have been wanting to make my own DeLorean dealership sign for some time and now I have finally got around to doing it.
I thought I would share the results on here for anyone else who might be interested in doing this.
Firstly I decided that I wanted an 8ft X 2 ft sign to suit my garage, this is approx two thirds the size of the original Dealership signs as they were 11ft 4in X 3ft
I visited a sign maker who does a bit of work for my business and explained what I was trying to do, he kindly made a few samples for the actual sign and I agreed on a style/method and he went ahead and made me two signs (the second one is for Barry, DBro 2).
The sign is made from 5mm thick opaque acrylic sheet with vinyl sheet stuck on the face to produce the lettering. The opaque acrylic material is ideal for diffusing the backlighting.
There is another method of making the sign front by using a clear acrylic sheet and a stencil with aerosol paints which would probably work out to be a bit cheaper but I decided to go this route as it is quite labour intensive and would take a great deal of care to produce good results in my opinion.
I then set about making the sign housing complete with white LED backlighting.
The back board is made from 12mm thick MDF, 2440mm long X 610mm High (exactly half of a 8ft X 4ft Sheet). I drilled a 10mm dia hole near each corner for the fixing screws for the sign, I done this so that I didn’t have mounting lugs showing on the outside of the sign.
I made the frame from 2” X 1” aluminium C Channel which I bought precut from my local metal supplier, I even got him to cut the mitres just to save me having to do it myself. The dimensions of these pieces were 2 off at 2450mm long and 2 off at 620mm long, this gives a gap of approx. 2mm all round to the edge of the acrylic (you don’t want it tight).
photo 21.JPG (97.69 KiB) Viewed 4852 times
For my sign I needed to slide the sign panel in from underneath once the sign housing was fixed to the wall so the bottom rail was left loose from the housing but the three other edges were fixed. Countersunk clearance holes were drilled in the aluminium and corresponding clearance holes were drilled in the MDF backboard, the aluminium frame was then fixed to the backboard by woodscrews which were screwed straight through into 27X27 PAR softwood around the perimeter of the MDF.
photo 1.JPG (93.52 KiB) Viewed 4852 times
photo 3.JPG (83.88 KiB) Viewed 4852 times
The result of this was to give me a 7mm gap which was ideal for the sign to slide into
Four countersunk holes were then drilled into the bottom rail in the 2” face so that it could be fixed to the softwood once the sign was slid in.
photo 23.JPG (72.37 KiB) Viewed 4852 times
I also screwed a softwood rail across the backboard and two vertical rails in order to give the sign some extra support and to provide some light separation inside of the housing
photo 4.JPG (106.83 KiB) Viewed 4852 times
The LED light strips come on a 5 metre roll and are the 60 LED/metre 3528 SMD’s which have ample brightness for the application, I bought them off EBAY, here is the link; http://www.ebay.co.uk/itm/161451028747, I needed 3 lots of 5 metres for this sign, there are 4 lengths behind the bottom lettering and 5 lengths behind the top letters, when I make the next sign I will use ‘jumper’ wires between adjacent strips rather than just continue with the strip. The strips are self adhesive and easily applied.
For anyone who fancies making a colour changing light please be advised that when set to white these lights have a slight pinkish tint so this is why I opted for single colour white.
For each 5 metre length used, the consumption is 2 amps so I bought a 6 amp power supply, again off Ebay to power the sign, dimmer controls are also available if required. For this sign I just drilled another hole in the MDF and ran the two 12v wires out of the back.
photo 12.JPG (71.58 KiB) Viewed 4852 times
Once the LED’s were fitted and connected I scuffed over the aluminium frame with some medium wet and dry and then sprayed it firstly with two coats of etch primer followed by a few coats of matt black.
photo 5.JPG (102.99 KiB) Viewed 4852 times
photo 11.JPG (90.08 KiB) Viewed 4852 times
To fix the sign to the wall I simply used four large screws with some large penny washers.
Once the sign housing was screwed to the wall, I slid the sign in and fixed the bottom rail in place.
photo 14.PNG (316.72 KiB) Viewed 4852 times
photo1 3.JPG (93.65 KiB) Viewed 4852 times
The guys who made these signs for me are really good, they now have the artwork all set up and they can easily produce any size sign up to this size (4 : 1 aspect ratio).
I am due to place another order with them in the next few days so if anyone is interested in making one of these themselves please let me know and we can probably get a good price if we order a batch.
The approx. total cost of the sign materials was as follows;
Acrylic sign ( 8ft X 2ft) £260
Aluminium £65
12mm MDF (full sheet) £18
PAR soft wood £12
LED’s £30
Power supply £15
Aerosol paints £30
TOTAL £430
(I believe that a 4ft X 1ft sign will cost about £130 and obviously all of the associated other materials will be less than the above)
Finally, I would just like to give a mention to DMCTodayMichael who is a member on this forum and has done a lot of work on this subject himself, you can check out his video; https://www.youtube.com/watch?v=LcVtaP6sfN8
Mike (DBro 1)
Mike Knowlton (DBro 1)
DeLorean DMC-12, VIN#4208,
mknowlton
VIN #: 04208
Re: Replica DeLorean Dealership Sign
Postby bandit » Sun Sep 13, 2015 10:04 pm
Great stuff Mike, that looks the bollox, very good
Postby Admin-bloke » Sun Sep 13, 2015 10:24 pm
Excellent write-up :D
Postby Domi » Mon Sep 14, 2015 7:28 pm
Looking very good :thumbsup:
Postby arranj » Mon Sep 14, 2015 10:14 pm
This is really well done! Nice one Mike :thumbsup:
Postby A Van » Mon Sep 14, 2015 11:16 pm
Stunning job well done Mike
Postby MikeWard » Tue Sep 15, 2015 8:58 am
It looks brilliant Mike :thumbsup: This is definitely on my todo list at some point.
Postby Admin-bloke » Tue Sep 15, 2015 9:41 am
Mr DBro1, I bet if you made a production line run of these, you'd definitely have a few takers!
Postby GDTDMC12 » Tue Sep 15, 2015 3:00 pm
Yes, if the price seems reasonable considering the costs mentioned then I'd be a taker.
:thumbsup: :D
Gareth.
Follow my blog
Road Trips
2019
2024
GDTDMC12
VIN #: 16606
