Vin 11766 Middle Eastern Car
Postby A Van » Mon Aug 03, 2009 1:01 pm
There are a whole load more photos at
http://s334.photobucket.com/albums/m405 ... n%2011766/
As you can see from the photos, this car was almost to parting out stage, but for some bizarre reason I took a shine to it, prob because of its Middle East history and so decided to start from the ground up!.
This list is more up to date than my paperwork file!
Chassis, stripped, galvanised and powdercoated inc rear control arms, fuel tank closing plate and various brackets etc.
New stainless recall plates.
New polybushes all round.
New sway bar kit. (DPNW)
New trailing arm bolts (Toby's Tabs).
New SPAX adjustable shocks all round.
Steering rack professionally refurbished
New steering column bush.
New track rod ends.
Front calipers professionally refurbished.
Rear calipers professionally refurbished.
New brake master cylinder.
New stainless brake hoses.
New Redstuff pads all round.
Wheels refurbished and repainted.
New tyres all round.
New coolant bottle.
Auto transmission rebuilt.
Engine, stripped, cleaned, serviced and repainted.
New alternator.
New fender antenna.
New 3 core brass radiator.
Entire new AC system inc hoses,condenser and compressor and evap core.
New seat covers.
New window motors.
New front headlights
New defrost switch.
Interior redyed.
Door Led kit.
Binnacle Led Kit.
AC panel Led Kit.
Headliners recovered.
New inner door seals.
New outer door seals.
Engine cover resprayed.
New stainless engine cover grills.
Fascias repainted.
New rear numberplate bezel
Door sill lettering.
Rear fascia lettering.
New headlights.
New rear wiring loom.
New accumulator.
New fuel filter.
New fuel pump.
New tank sender.
New battery.
New fuel hoses.
New front speakers
New rear speakers.
New CD player.
New sunvisors.
Drivers side torsion bar replaced.
Passenger side torsion bar replaced.
Lower steering canopy replaced.
Binnacle lens replaced.
Rebuilt mode switch.
New washer bottle.
Replaced bonnet hinge.
New door vents x 2
New passenger window glass.
New struts all round.
New relays.
New driveshaft boots.
New Louvre rubbers.
New blower motor.
New hazard switch.
New door guides.
Refurbished starter motor.
New angle drive.
New manifold gaskets
New centre caps.
New DMCH floor mats.
New marker lenses.
Full stainless rebrush.
New Freeflow stainless exhaust.
Still got a few things to sort out, central locking etc.
It wouldn’t have been possible without several people in no particular order!!
Martin Gutkowski
James Russell Grant
Nick Tomlinson (Engine Diagnostics and tuning)
Mike Bosworth
Jay Wright
Chris Nicholson - PJ Grady UK
Ed Uding
James Mead - Master Garage, Braintree, Essex
Richard Johnstone
James Espey
Bob Miller
Josh Haldeman
Think I remembered them all!
UPDATE 26/10/09
Vin 11766 has now been converted to a manual car!, some pics of the gearbox in the car here.
Also have replaced the front springs with the new stiffer ones, new track rod ends, new heavy duty balljoints, lower arms stripped and reinforcing plates welded in etc.
New clutch, master cylinder and slave.
I drove the car yesterday and it is totally transformed the ride, my previous Euro springs had started to collapse.....
Without certain people the conversion to manual wouldnt have been possible, several things all came together at once.
Chris Nicholson
Matthew Nickels
Dan Stacey
Tyson
TT
Lawrence Lormand
Misty Petersen
Cheers you lot, and a special mention to Chris N, the guy is one in a million we are very lucky to have him in the UK!
Al
Re: Vin 11766 Middle Eastern Car (Mine this time!)
Postby jerzybondov » Mon Aug 03, 2009 2:00 pm
And I thought my list of changed/new parts was long!
Postby A Van » Wed Aug 05, 2009 12:08 pm
I know its frightening......!
Postby tourettes tony » Wed Aug 05, 2009 7:46 pm
i lost count of mine when it got to 6k lol TT
Postby Domi » Sun Aug 09, 2009 7:50 pm
Wow, you did a great job :shock:
Postby A Van » Sun Aug 09, 2009 7:52 pm
Thanks Domi.
In the French club who was the guy that restored the yellow DeLorean from the UK?
I remember there being some really awesome pictures
Could you post the thread over here?
Merci
Al
Postby Domi » Sun Aug 09, 2009 8:02 pm
A Van wrote:Could you post the thread over here?
No problem, here it is:
http://delorean.fr/forum/viewtopic.php?t=926
Postby A Van » Sun Oct 25, 2009 7:50 pm
Updated at the top!
Postby arranj » Sun Oct 25, 2009 8:23 pm
How are the springs Al? Be good to see some ride height shots too! :)
Postby A Van » Sun Oct 25, 2009 8:43 pm
Yes, I'll get some done asap...raining on Sat!
The ride height at present is slightly higher than normal, but will settle down over next few days.
It has made a major difference to the drive, Chris N who has even driven countless DeLoreans commented himself on how well it drove.
Return to Middle Eastern Cars
Users browsing this forum: No registered users and 23 guests
