Frequency valve
Frequency valve
Postby Phil349 » Tue Nov 17, 2015 12:24 am
Hi,
I'm in need of a frequency valve please if anyone has one available for sale.
Cheers,
Phil.
Phil349
VIN #: 1128
Re: Frequency valve
Postby DMCD » Tue Feb 14, 2017 4:31 pm
Phil349 wrote:Hi,
Cheers,
Phil.
. I have been me if you're still interested.
DMCD
VIN #: 4285
Re: Frequency valve
Postby Admin-bloke » Tue Feb 14, 2017 6:38 pm
Phil349 wrote:Hi,
Cheers,
Phil.
You've probably checked this out already, but
just a quick tip before condemning the frequency valve, remove the white electrical connector plug on the frequency valve and check to see if one of the pins has 12v to it with the engine running. If it doesn't, it could be that there is a fault with the lambda relay being the incorrect type (especially so if just replaced) or that there is a connection issue at the "church window" electrical connection under the coil cover or the lambda/fuel computer itself not powering up (or missing earth from one of the two earth connections at the computer)
Good luck either way
Users browsing this forum: No registered users and 31 guests
