Postby Domi » Sat Nov 14, 2015 7:19 pm
All right, thanks for the advice ;)
Postby Admin-bloke » Sat Nov 14, 2015 7:24 pm
Domi wrote:All right, thanks for the advice ;)
You're welcome. It's easier to check it now than finding out once the engine is all back together ;)
Postby Domi » Sat Nov 21, 2015 6:04 pm
I'm trying to remove the two screw of the cross brace.
The screw on the right seems to unscrew easily but the one from the left doesn't coming, and I don't want to break it.
The car sits on the frame for now, so no strength on these screw?
Any advice to remove those screws please?
Postby A Van » Sat Nov 21, 2015 6:25 pm
Is it stuck tight? Or spinning?
Postby Domi » Sat Nov 21, 2015 6:59 pm
It's spinning a little bit, but now it does not move.
I don't want to break it, so I put some WD40 on it.
Postby A Van » Sun Nov 22, 2015 9:53 am
Keep working it back and forth slowly
Postby Domi » Sun Nov 22, 2015 10:48 am
I will try to raise up the front a little bit, but not on the frame like we can see on the picture above.
Maybe the car is not really flat so there is a strength on the bolt.
Postby Domi » Sun Nov 22, 2015 6:06 pm
I try gently but it looks like the bottom nut "swimming"?
It should not be welded to the frame?
I'm not sure, but it seems that there are as a location and the nut is twisted?
Well I stop I losing patience :evil:
Postby A Van » Sun Nov 22, 2015 7:07 pm
It should just undo... Keep with the wd40 back and forth
Postby Domi » Sun Nov 22, 2015 7:58 pm
Looks like there is a square bolt under which turn on itself.
