Postby Domi » Sun Nov 22, 2015 8:16 pm
Well, maybe I was dreaming :roll:
Passenger side screw is out :dance:
The other one take a bath on WD40 :think:
Postby A Van » Sun Nov 22, 2015 8:50 pm
It's a captive nut in chassis
Postby Domi » Sun Nov 22, 2015 8:59 pm
All right, let's hope I won't damage it.
Postby A Van » Sun Nov 22, 2015 9:35 pm
You can't if you take it easier
Postby Domi » Sun Nov 22, 2015 9:40 pm
I hope you're right :mrgreen:
Postby Domi » Mon Nov 23, 2015 7:20 pm
So, I was able to remove the last screw. Below the screw, I have a square nut which I hold with a screw driver to avoid it to move.
A little bit rusty but I will clean them and they will be like new.
Let’s hope I will be able to do it again when I will be ready to put the cross brace back.
A few pictures, but sorry for the bad quality, I guess my camera is a little bit tired
Here are some pictures of my cross brace, this way, you will understand why I needed to remove it to repair it properly.
Here is where I am so far, going slowly
Postby Domi » Sat Dec 19, 2015 5:53 pm
Before replacing the cross brass, I wanted to change the gas line, but it's one week that soaked in WD40 unsuccessful, nothing moves :evil:
Patience :mrgreen:
Postby Domi » Sun Jan 03, 2016 7:47 pm
Finally made it!
A little cleaning
Let’s do the other side…
Postby jamesrguk » Mon Jan 04, 2016 2:36 pm
Interesting to see that those headers only use two exhaust studs, just out of curiosity where did that come from?
James
Postby Domi » Mon Jan 04, 2016 8:27 pm
James
You mean the exhaust pipes?
If so, it was hand made by a French company back to 1996 because it was unavailable at this time.
