Postby Domi » Sun Jan 10, 2016 9:31 pm
I didn't think about that, great idea!!!
Thank You ;)
Postby Admin-bloke » Sun Jan 10, 2016 9:32 pm
Domi wrote:I didn't think about that, great idea!!!
Thank You ;)
You're welcome.
Postby Domi » Sat Jan 16, 2016 7:30 pm
I forgot this part last time
This one need to be restored
I have removed the pipes from the hot water valve and back water pump. Not a lot of room to remove them
Success, hot water valve removed but I can’t do the new because some clamps are missing in the kit
New pipes looks nice
Postby Domi » Sat Jan 23, 2016 7:29 pm
The bracket has been painted
On the frame with the stainless pipes
Coolant pipes, I had to cut the length of one of them because it was a little bit too long
Removing the clutch pipe
New sensor
New screws
Valve covers are back in place with the AC
New stainless pipe with its bracket
Postby Domi » Sun Jan 31, 2016 6:39 pm
Stainless Clutch and bracket
Hot water valve with its new pipes
Postby Admin-bloke » Sun Jan 31, 2016 7:14 pm
Keep up the good work Mr Domi :thumbsup:
Postby Domi » Fri Feb 05, 2016 11:02 pm
New rotor and cap
Old sparks
New stainless water pipe
New seals
This parts doesn’t look good because the hole wasn’t correct for the screw, so I had to replace it with a bigger one
I have to find the two other screws somewhere
Postby Domi » Sat Feb 06, 2016 9:29 pm
The bracket of the resistor is very rusted, so I need to remove it to change it
Does everyone remove the capacitor on the coil?
New sensor on the engine block
Postby Domi » Sat Feb 13, 2016 9:18 pm
New connectors
Clutch Bleeder
Looks like I have a problem with my stainless pipes water kit
New grounds wire
New spark plug wire
Injector needs cleaning
Postby Delta Delorean » Sun Feb 14, 2016 10:33 am
Nice job Domi !
Good to see how it needs to be done.
Planning to do VOD and coolant hoses next winter on my car.
Where did you order the bleeder extention for the clutch cylinder?
Where in France do you live? I have traveled there a lot the last weeks for work.
Delta Delorean
VIN #: 5823
