Bent Tabs worn TAs
Re: Bent Tabs worn TAs
Postby Admin-bloke » Sun Jan 17, 2016 8:01 pm
Excellent !
Postby mec » Sun Jan 17, 2016 9:21 pm
top work !
Postby DJK73 » Tue Jan 19, 2016 6:47 pm
Right all back together now
Took it to the wheel alignment centre in Southampton today and what an excellent job they did
Im very happy with the result, the car drives true and handles really well now
Big thanks to admin bloke for his tech assistance
Dan
Oh no it's dirty already !
Dbro4
Ex Vin#10223
Grey interior, Manual
Free flow
DJK73
VIN #: 10223
Postby Admin-bloke » Tue Jan 19, 2016 9:18 pm
You're welcome Dan.
I've got to say that is one of the best results I've seen on a geometry report. That result is more accurate than most new cars. Considering that you've reworked the rear, it's an excellent result.
I bet it drives a lot better than it originally was.
Looking at the before and after readings, I bet you could even tell the difference on the ride to the alignment place and back.
Great work :thumbsup:
Postby jamesrguk » Tue Jan 19, 2016 11:21 pm
I'm going to do some investigation into the rear suspension on my car this Saturday.
The front end is tight as a drum as I have just done a major overhaul, but the back end feels so disjointed and it's like it is drifting all over the place, it makes for a very uneasy driving experience.
I am hoping that it may be an alignment issue, the TABs were changed about 5years ago to the stronger inconel tabs, I then had a 4wheel alignment done at which point the car handled really quite well. I am now wondering if a shim has fallen out of the TAB joint resulting in play in the suspension.
It sounds like the OP had some very similar characteristics.
James
Postby MikeWard » Wed Jan 20, 2016 8:29 am
Nice work Dan, I'll be looking forward to treating mine to an alignment once my new suspension parts have arrived and have been fitted.
jamesrguk wrote:I am hoping that it may be an alignment issue, the TABs were changed about 5years ago to the stronger inconel tabs, I then had a 4wheel alignment done at which point the car handled really quite well. I am now wondering if a shim has fallen out of the TAB joint resulting in play in the suspension.
Did you change the trailing (radius) arm bushes when you changed the TABs?
Bent Tabs worn TAs
Postby A Van » Thu Feb 25, 2016 8:46 am
With all the new parts, work , upgrades and Chris N rebrush Dan K car has to be up there at the top in the UK.
Postby Dan 6511 » Thu Feb 25, 2016 3:30 pm
Hi Dan, I noticed you have changed the bolts for the driveshafts to cap heads. Where did you get those? The standard hex heads are a pain in the arse to do up as you can't get a socket on them I found.
Postby dmc4087 » Thu Feb 25, 2016 4:09 pm
Dan 6511 wrote:Hi Dan, I noticed you have changed the bolts for the driveshafts to cap heads. Where did you get those? The standard hex heads are a pain in the arse to do up as you can't get a socket on them I found.
Good spot, interested in this myself.
Postby DJK73 » Thu Feb 25, 2016 6:15 pm
Well spotted guys
That is one of the Dmods I have tried out for the club
Yes they are a pain with hex head and these cap heads are much easier to work with
You will be able to buy them from the club soon
Dan
Dbro4
Ex Vin#10223
Free flow
DJK73
VIN #: 10223
