Latest project cars VIN 2395 and VIN 2486
Postby mknowlton » Wed Feb 03, 2016 3:09 pm
So Barry and I had a fun day last week finally taking a look at a couple of project cars that we imported towards the end of last year.
We bought both cars as non-runners, one is a black interior auto and the other is a black interior manual.
The bodywork and interior is pretty good on both the cars, however, although ‘running when parked’ they both need the standard stuff normally required for project cars that have been idle for some years ie; fuel pick up hose, filter, new fuel pump, new gas struts, Fascias to be painted, brakes, suspension etc.
We started with the manual car, fitted a new battery and pulled out the fuel pump and fitted a new one which we dunked into a jug of fresh fuel. We also filled the cooling system with coolant to find that there was no leaks evident
The clutch is not functioning, probably due to leaked fluid/perished seals.
All of the electrics came to life immediately with the exception of the windows.
We jumped the fuel relay and flushed out the fuel system, the engine turned nicely but the engine struggled to fire, we quickly diagnosed that the plunger in the fuel distributor was stuck.
We swiftly removed the distributor, freed it up and refitted it. The engine fired up straight away and sounds great, obviously a full overhaul/ tune up is required but first impressions are good.
We then looked at the auto with much the same outcome with us having to free the plunger in the fuel distributor and the engine came to life, again sounding very nice.
We managed to put it in gear to drive it backwards and forwards so that was quite encouraging although we have a serious coolant leak from the water pump so it very much looks like a trip down to the VOD is required!
I must say that it is a great feeling when you fire up an engine which has been ‘resting’ for years.
We just need to decide what we are going to do with the cars now but first and foremost we really must complete our restoration of 3283.
I will post separate threads on these two cars if/as we decide to restore them ourselves.
Mike Knowlton (DBro 1)
DeLorean DMC-12, VIN#4208,
mknowlton
VIN #: 04208
Re: Latest project cars VIN 2395 and VIN 2486
Postby MikeWard » Wed Feb 03, 2016 3:32 pm
Nice work as always dbros :jzd:
Postby A Van » Wed Feb 03, 2016 4:03 pm
Outstanding from the DBros
Postby Admin-bloke » Wed Feb 03, 2016 5:10 pm
Excellent!
It's nice to see another fine quality black manual.
Keep up the good work as ever :D
Postby bandit » Wed Feb 03, 2016 6:13 pm
Nice one Mike, plenty to keep you busy there then, for a while
Postby DMCDELLBOY » Wed Feb 03, 2016 6:21 pm
do you need any new fuel tanks mike ; I have some if you need any.
DMCDELLBOY
VIN #: 11075
Postby Domi » Wed Feb 03, 2016 7:05 pm
Amazing, congratulation on your purchase :clap:
Postby mec » Thu Feb 04, 2016 12:19 am
very nice indeed guys !
Postby mknowlton » Thu Feb 04, 2016 7:41 pm
DMCDELLBOY wrote:do you need any new fuel tanks mike ; I have some if you need any.
Thanks Malc,
I am not sure on the condition of these yet but if we find that they are bad I will certainly be in touch!
mknowlton
VIN #: 04208
Postby Biff » Sat Feb 06, 2016 11:21 am
Loving it Mike, You guys must be responsible for 50% of all imports!
Where did they come from, easy/smooth purchase & shipping?
Biff
VIN #: 05127
