Postby Domi » Sun Feb 14, 2016 10:39 am
Thank You :greetings-waveyellow:
I have ordered the clutch bleeder on John's Hervey website, here is the link:
https://www.specialtauto.com/delorean-p ... ssion.html
I live near the city of Grenoble near the French Alps ;)
Postby Domi » Sun Feb 14, 2016 6:25 pm
New oil pressure sensor
Nevertheless, it does not screw everything, please see picture below. Does this happen to anyone else? (I hope it won’t leak oil)
New wire from the starter to the alternator bigger and longer to avoid heat from the exhaust pipe
Postby Domi » Tue Feb 16, 2016 9:32 pm
WUR cleaned
Postby Domi » Thu Feb 18, 2016 7:53 pm
The stainless bracket is back in the engine compartment, and a new coil
Postby Admin-bloke » Thu Feb 18, 2016 8:48 pm
Looking good there Mr Domi, don't forget those vacuum pipes:
viewtopic.php?f=17&t=1030
viewtopic.php?f=17&t=4619
Thanks for sharing :D ;)
Postby Domi » Thu Feb 18, 2016 9:23 pm
I have bought them from John H. in Red.
Didn't install yet, but soon.
Anyway, thanks for the links, that helps ;)
Postby Admin-bloke » Thu Feb 18, 2016 9:24 pm
Domi wrote:I have bought them from John H. in Red.
Keep the pictures coming :D
Postby Domi » Thu Feb 18, 2016 9:29 pm
Sure don' worry ;)
Postby Domi » Mon Feb 22, 2016 9:32 pm
Injectors are ready for a new seal and a new hook
Not so easy to remove and to put on the new one
Soak in WD40 and with the help of a 14 wrench push to remove the seal
Same thing in reverse to put the new seal
Injectors are finally ready
With the new stainless steel fuel lines
In the engine compartment
Postby Admin-bloke » Mon Feb 22, 2016 9:46 pm
Looking great there.
For replacing injector seals, I use a deep socket and a rubber headed hammer to drift them off.
viewtopic.php?f=17&t=119&start=20
It looks like you're almost there
