Postby Admin-bloke » Mon Mar 28, 2016 4:55 pm
Keep up the good work
Thanks for sharing ;)
Postby Delta Delorean » Mon Mar 28, 2016 6:21 pm
Nice work Domi!
I am planning on replacing al my cooling parts next winter, want to first get my D registerd and drive it arround locale.
I am replacing the fuel line from the filter to the fuel head with a stainles one like you did. The old one scared me.
Are you going to replace your radiator? If so where did you buy a new one?
Buying al those parts I understand that you run out of funds to go to Belfast. I am in the same position....
Delta Delorean
VIN #: 5823
Postby Domi » Mon Mar 28, 2016 8:35 pm
Yes I will replace my radiator.
In the past I bought an aluminum one from a French maker but the original shroud didn't fit well, you have to cut a few millimeter of plastic.
I'm trying to sale it over the French forum.
So, I bought another one from John Hervey in copper instead of aluminum.
I need to order two fan from DPN. (I had ordered the fan from Ed Uding but don't want to keep them)
And yes, Belfast will be for the future... maybe.
Postby Domi » Mon Mar 28, 2016 8:38 pm
A few pic
Postby andyd » Tue Mar 29, 2016 12:19 am
Nice Domi,
I fitted Eds rad and fans, on the OEM shroud. Fitted well, and works well too.
Postby Domi » Sun Apr 03, 2016 7:58 pm
I have painted the rusted area with POR15
Before:
After:
Everything will disappear to come back to original
New circuit breaker
Postby Domi » Sat Apr 09, 2016 9:13 pm
Stainless steel plate under the tank, done! Not an easy task alone.
One more pipe and it will be okay under the car :)
Postby Domi » Sun Apr 10, 2016 8:41 pm
Last silicone pipe under the car done
Removed the radiator & fan
Postby Domi » Sat Apr 16, 2016 6:05 pm
Painting
And cleaning today
Postby Domi » Sun Apr 17, 2016 6:11 pm
Assembly
And removing old rusty rock screen
