I had to remove POR15 on the bracket because it didn't hold on. So, now I wonder if I try to paint it black or invisible paint to protect it like it is now.
A little bit tired after all the work done so far...
The radiator and fans and back on the car, not so easy lying under the car Replacing the bracket, new horns with stainless bracket and also stainless bracket for the radiator.
I’m trying to mount the radiator duck, but not so easy to do it. On side only is okay for now.
When you take a look on Ed’s site or Houston it’s a two part component now? We’ll see that tomorrow, after 4 hours of working on the car, I’m a little bit tired.
I wanted to redo the level of clutch fluid today and despite the valve is operating, nothing comes out? Without the valve, the liquid reaches well, so I assume that the valve is defective. I do not know if I can find it here or if John can provide me another in exchange.
Otherwise, I installed my new gas line, which should prevent leaks at the filter.
