Postby bjbrownie » Mon May 16, 2016 8:18 pm
Nice work there-it got me thinking about the gearbox ground wire,mine doesn't have one-is that a modification fitted to later DMCs? There's only a braided flat ground wire going from the RH side engine mounting to the rear chassis frame below the engine on mine.
bjbrownie
VIN #: #10556
Postby Domi » Mon May 16, 2016 8:49 pm
There is just a hole in the first place.
Then I add the wire sold by John on his website to improve the negative earth.
Postby Admin-bloke » Mon May 16, 2016 9:11 pm
bjbrownie wrote:Nice work there-it got me thinking about the gearbox ground wire,mine doesn't have one-is that a modification fitted to later DMCs? There's only a braided flat ground wire going from the RH side engine mounting to the rear chassis frame below the engine on mine.
Why do you need an earth wire on the gearbox when there is a main chassis to engine block braided cable? The main point to look at is the integrity of the connection between the black cable from the negative post to the metal chassis itself and then the braided cable at the engine block itself.
If you want to fit a supplemental cable, connect one to the engine block as the largest current usage is via the starter motor.
This is from a tight-fisted Northerner who doesn't spend anything without having to, but without compromising safety or reliability :lol: :jzd:
Postby Domi » Sat May 21, 2016 8:25 pm
New fuel pump to replace the old one (21 years old)
The old pump wasn’t rusty and the boots not too damaged.
The tank isn’t too dirty but deserves to be cleaned
Taking back the old connector to the fuel pump
Postby Domi » Sun May 22, 2016 5:06 pm
She's thirsty :mrgreen:
New fuel pump installed :P
Postby Admin-bloke » Sun May 22, 2016 6:28 pm
Nice pictures, Thanks for sharing :jzd:
Postby MikeWard » Sun May 22, 2016 8:15 pm
Don't throw the old parts away. The baffles are no longer available.
Postby Admin-bloke » Sun May 22, 2016 9:18 pm
MikeWard wrote:Don't throw the old parts away. The baffles are no longer available.
Good point Mike !
Postby Domi » Mon May 23, 2016 7:52 pm
Don't worry I kept the old parts, we never know what could happen :whistle:
Postby Domi » Sat May 28, 2016 6:05 pm
New battery terminal from the club, fits perfectly, thank you :P
Users browsing this forum: No registered users and 27 guests
