Door Latch Needed
Door Latch Needed
Postby asifmalik » Wed Jun 22, 2016 2:19 pm
Hi Guys
I need a door latch, drivers side, front latch.
Ed only seems to be selling them in packs of four, maybe someone has the one I need?
See pic
VIN 1797, Twin Dealer Stripes, Dark Rims, Black Interior, Gas Flap, D-Locked, brushed by the master.
asifmalik
VIN #: 1797
Re: Door Latch Needed
Postby mec » Wed Jun 22, 2016 2:21 pm
whats wrong with it ?
Postby asifmalik » Wed Jun 22, 2016 2:23 pm
It jammed, and when i try and move it open with a screwdriver it's not smooth at opening and catches.
I've lubricated it, but for the time being Im driving with the striker pin removed so that I dont get locked in.
I also think the rods may need adjusting...
asifmalik
VIN #: 1797
Postby mec » Wed Jun 22, 2016 2:40 pm
Thats what i was going to suggest, adjusting the rods, I had to do my pass door for the opposite reason, it wouldn't latch, as soon as i adjusted the rods it works fine, might be worth trying this 1st as even if the latch isn't smooth it should still release when you push the door open as long as the rods are adjusted ok
Postby Admin-bloke » Wed Jun 22, 2016 2:45 pm
DBro1 is the latch master!
Postby MikeWard » Wed Jun 22, 2016 2:46 pm
If you get stuck I may know someone who has used latches, I'll drop him a message now.
Postby mknowlton » Wed Jun 22, 2016 3:15 pm
I think it will probably be adjustment Asif as Mec has said.
If you are coming to Norfolk next month we can have a look at it then if you like.
If Mike W can get hold of a spare latch then better still, FYI I believe that the drivers front latch is the same part as the passenger rear and vice versa.
Mike Knowlton (DBro 1)
DeLorean DMC-12, VIN#4208,
mknowlton
VIN #: 04208
Postby asifmalik » Wed Jun 22, 2016 3:25 pm
Thanks Mike K,
Im still in progress of making plans for Norfolk.
Mike W, let me know if there is any latches available.
Asif
asifmalik
VIN #: 1797
Postby Daniel Shane » Wed Jun 22, 2016 10:20 pm
Lotus Elise S1 and S2, Vauxhall VX220 are the same latches. Allegro I believe is the original source
Dan Shane
DCUK 008
Ex VIN 4754
The Black Stig
Daniel Shane
VIN #: Ex 4754
Postby arranj » Thu Jun 23, 2016 3:48 pm
Or just buy one from the club store ;) - http://www.deloreanclub.uk/door-latch-r ... front.html
