Postby andyd » Sat Nov 26, 2016 9:43 pm
Can you get smaller bushes, eithed half inch or 12mm, which you would then have to ream?
I think the metal tube is bonded to the rubber?
Postby arranj » Sat Nov 26, 2016 9:48 pm
I can't say I've ever heard of anyone doing this.....? Just stick the bolts in and tighten them up, job done?
Postby Domi » Sat Nov 26, 2016 10:04 pm
Once the bolts will be tighten, I think everything will be fine.
Postby A Van » Sun Nov 27, 2016 2:41 am
Once tightened no problem
Postby Domi » Sun Nov 27, 2016 8:39 pm
New isolator spring
Front cut spring VS Eibach
New Spax shocks & Eibach springs
There is a gap with theses polybushing. Does anyone encounter that kind of problem?
Postby Domi » Sat Dec 03, 2016 9:24 pm
Next step:
Postby Domi » Sun Dec 11, 2016 5:26 pm
Postby Domi » Sat Dec 17, 2016 6:04 pm
Let's work on the rear of the car
Do I have to cut the clip to get back the rear spring platform?
Postby Domi » Sun Dec 18, 2016 5:39 pm
The hard way :mrgreen:
Postby Domi » Sat Jan 07, 2017 10:22 pm
New bushing and started to paint the arm
