Postby Domi » Sun Apr 02, 2017 5:33 pm
Postby Domi » Sun Apr 02, 2017 5:47 pm
Postby Domi » Sat Apr 08, 2017 6:15 pm
Postby Domi » Sun Apr 09, 2017 7:42 pm
Unknown parts?
Postby Thibaut » Mon Apr 10, 2017 6:44 pm
The v-shaped metal clip is #39
and i bet the black plastic disc is #43
Both are not even listed on the Store... keep them !
#39 is meant to facilitate insertion of the clock panel ''tubes'' into the center console inner brackets
FWIW, i don't have it on my car and insertion is always tricky...
Try without first, then with, and let us know :)
EDIT :
an old copy of the parts manual tells me #39 is actually SP10557, and they're supposed to be 4 per car, obviously
#43 is SP10042, "shakeproof washer M6". One car should require 6 of these
Thibaut
VIN #: 05191
Postby Domi » Mon Apr 10, 2017 7:10 pm
Thanks for the answers Thibault ;)
Next...
Postby Domi » Fri Apr 14, 2017 8:27 pm
New brackets for the rear speakers
Postby Delta Delorean » Fri Apr 14, 2017 9:26 pm
Nice work Domi. Put it back together and get it on the road this spring!
Delta Delorean
VIN #: 5823
Postby Domi » Fri Apr 14, 2017 9:37 pm
Thank you, I hope so ;)
Postby Domi » Sat Apr 15, 2017 9:27 pm
