Postby InoX » Tue Sep 05, 2017 8:40 am
Did you manage to tighten down the hoses alright? I don't think I nipped mine up properly. When I went to tighten down the nut on the fixed line the flexible hose would rotate within the chassis mounting. Think I need to shim the hose within the mounting.
I replaced the plywood on the passenger side on my other car a few years ago. It was rotten. Look up project 3193 I think it was post from around 2008 or 2009 . Ended up making my own board. Just used a router and a wood saw and some pva glue. Was quite pleased with the result. I did post pictures of the construction. Used the old one as a template. From memory it was 1/2inch ply. Good luck.
InoX
Postby MikeWard » Tue Sep 05, 2017 9:08 am
gruffalo wrote:I would like to clean out the brake fluid reservoir better. I tried using acetone but not all the gunk dissolved. Any suggestions?
Run it through the dishwasher :thumbsup:
Postby gruffalo » Tue Sep 05, 2017 2:01 pm
InoX wrote:Did you manage to tighten down the hoses alright? I don't think I nipped mine up properly. When I went to tighten down the nut on the fixed line the flexible hose would rotate within the chassis mounting. Think I need to shim the hose within the mounting.
I got my hoses from deloreango and they came with locking washers that in my case did a great job. The flex hose held steady while tightening the 13mm fixed line but. No need to exaggerate tightening them down either, snug will do.
Postby InoX » Tue Sep 05, 2017 6:50 pm
hi
yeah. didn't try to over do it, but the driver's near side is weeping. noticed it when i was replacing the clutch hose.
plus the off side front flex hose as rotated and now fouls the upper control arm in some conditions. need to go back in and shim then.
the appeture for the hose is narrower than the mating surface on the arm so as it gets pulled tighter it has nothing to fit against and moves around. must just be me. I'll give it another bash.
InoX
Postby InoX » Tue Sep 05, 2017 7:46 pm
Just looked and apparently either i didn't upload the photos i said i did or i removed them. These are photos of the project i started on vin 3193. here you go:
ImageIMG_0058 by Justin Drexler, on Flickr
ImageIMG_0059 by Justin Drexler, on Flickr
ImageIMG_0064 by Justin Drexler, on Flickr
ImageIMG_0062 by Justin Drexler, on Flickr
ImageIMG_0065 by Justin Drexler, on Flickr
ImageIMG_0068 by Justin Drexler, on Flickr
InoX
Postby gruffalo » Tue Sep 05, 2017 9:46 pm
InoX wrote:hi
Om my car there are brackets with sort of hex inserts that keep the flex hoses from rotating.
Postby gruffalo » Tue Sep 05, 2017 9:53 pm
InoX wrote:Just looked and apparently either i didn't upload the photos i said i did or i removed them. These are photos of the project i started on vin 3193. here you go:
Wow great and inspiring work! I'll do the same when I get to the interior.
Btw what's going on in this photo?
Mystery job...
Postby InoX » Tue Sep 05, 2017 10:00 pm
I'm reattachingthe rear speaker card. I've used a polyurethane adhesive and used the clips to hold the vinyl to the underbody. The cling film is to prevent the clips from sticking to the adhesive and vinyl.
InoX
Postby gruffalo » Tue Sep 05, 2017 10:02 pm
Got a short work session in today as well. Fitted the front right caliper and flex hose.
In addition I completed the last of the rear calipers, since I got another shipment of parts today. :)
I also installed the rear right caliper. The last caliper has got some fouled threads so I need to run a threading tap through them before I fit the hard line. The necessary bits are in the mail.
Rear Right all done
FR. Thin coat of rust cosmetic problem only
Postby gruffalo » Wed Sep 06, 2017 9:05 pm
Slow but steady progress:
Got the clutch slave installed without any issues. Also cleaned out the clutch fluid reservoir. Paint thinner and a homemade giant q-tip did it.
Slave found its new home
Cleaned out ... good enough
Reservoir flushing rig
Users browsing this forum: No registered users and 28 guests
