VIN 0944 For Sale £31,500
Postby InoX » Sun May 27, 2018 3:43 pm
Hello.
For Sale my 81 Delorean. Vin 00944. Black interior Manual transmission. Mileage 30,771
Reason for sale: I've had enough.
Runs, drives, steers, brakes
V5 in place.
£31,500
Open to offers, naturally.
What's recently been done in the last 18 months:
New flexible brake lines - Club
new brake master cylinder / reservoir - Saab
New stainless braided clutch - Club
LEDs on interior - Club
Kenwood radio & xxxx speakers - Other vendors
power antenna – Other vendor
New pancake cooling fans - DPNW
New aluminium radiator - Club
silicone coolant hoses all around – Club/other vendor
re-built control pressure regulator - Club
New wheel nuts. - Lotus
Lower arm bolsters re-leathered and re-attached. - Nick
binnacle re-leathered. - Nick
SPAX all around - Club
New lower front springs - Club
New lower ball joints. - Club
Front lower control arm boxed in and powder coated. - Club
Fuse box - Club
New engine bay fuel hoses including stainless send and return and FV hoses - Club
New fuel pump and filters - Club
Fuel tank cleaned out - Me
MattAliner console bracket - Club
new outer door locks. - Club
Headlight switch saver relay - Club
New A/C idler pulley bearings – Other vendor
Coolant Otterstat and aluminium pipe - Club
New window switches - Club
poly bushes on front. - Club
Stainless door struts - Club
painted trunk SEM trim black - Me
Stainless headlight finishers – Club
New water pump thermostat – Club
Vacuum heater selector switch silicone gasket – Club
Hazard Switch – Club
Head light Switch – Club
New instrument circuit board – Club
hood seal – other vendor
Having previously:
rebuilt all brake calipers – PJ Grady
rebuilt steering shaft. - Other vendor
Installed steering column bushing - DPNW
fuel level sender – Delorean Houston
UK fog light modification - Me
power window motors - A1
metal door handles - Houston
stainless coolant bottle – Hervey?
water pump with Volvo pulley - Club
Pirelli tyres – Other vendor
tie-rod ends – Other vendor
stainless heater return pipe - Hervey
painted VOD (POR 15) - Me
silicone vacuum hoses - Hervey
Early car starter voltage modification - Me
door lock module modification - Me
door lock solenoids - DPNW
Cat bypass - Gutkowski
outer door seals - Hervey
fuel tank enclosure plate galvanized - Wedge
Front wheel hub bearings – Other vendor
Front rotors – Other vendor
140 amp alternator - Hervey
washer bottle pump – Other vendor
all relays replaced except the Main and AUX - Hervey
Leather gear stick gator – Other vendor
Heated convex mirrors – Delorean One
water pump bleeder kit – DPNW
Think I replaced the TTS at some point.....
Gear stick noise dampener – Houston.
Heater blower motor – Hervey
What's not so good:
A/C needs charging
Front (and possibly rear) bumper need repainting. Previous owner didn't do a decent job on them. Various chips on the bumpers here and there.
There are at least two decent size dings on the driver's side.
Louvers are painted gloss black. Again the PO did this.
Centre caps on wheels are for the silver wheels. The wheels on this car are Grey.
Wheels could do with being professionally recovered.
Split in a seam in the passenger seat. Otherwise in decent shape.
Alignment of panels isn't great (early car).
Still has original exhaust (minus the CAT)
No MOT.
£31,500
Open to reasonable offers, naturally.
sorry about the contrast on the interior pictures, it's a bright day and it's a dark interior.
ImageIMAG0184 by Justin Drexler, on Flickr
ImageIMAG0193 by Justin Drexler, on Flickr
ImageIMAG0192 by Justin Drexler, on Flickr
ImageIMAG0189 by Justin Drexler, on Flickr
ImageIMAG0182 by Justin Drexler, on Flickr
ImageIMAG0183 by Justin Drexler, on Flickr
ImageIMAG0188 by Justin Drexler, on Flickr
ImageIMAG0187 by Justin Drexler, on Flickr
ImageIMAG0186 by Justin Drexler, on Flickr
ImageIMAG0185 by Justin Drexler, on Flickr
ImageIMAG0190 by Justin Drexler, on Flickr
ImageIMAG0213 by Justin Drexler, on Flickr
ImageIMAG0215 by Justin Drexler, on Flickr
ImageIMAG0214 by Justin Drexler, on Flickr
ImageIMAG0205 by Justin Drexler, on Flickr
ImageIMAG0210 by Justin Drexler, on Flickr
ImageIMAG0207 by Justin Drexler, on Flickr
ImageIMAG0206 by Justin Drexler, on Flickr
ImageIMAG0208 by Justin Drexler, on Flickr
ImageIMAG0212 by Justin Drexler, on Flickr
ImageIMAG0194 by Justin Drexler, on Flickr
ImageIMAG0195 by Justin Drexler, on Flickr
ImageIMAG0196 by Justin Drexler, on Flickr
ImageIMAG0197 by Justin Drexler, on Flickr
ImageIMAG0198 by Justin Drexler, on Flickr
ImageIMAG0202 by Justin Drexler, on Flickr
ImageIMAG0201 by Justin Drexler, on Flickr
ImageIMAG0203 by Justin Drexler, on Flickr
more pictures here:
https://www.flickr.com/photos/141950172@N03/with/42386694211/
and here:
https://www.flickr.com/photos/32731331@N04/
InoX
Re: VIN 0944 For Sale £31,500
Postby InoX » Sat Aug 25, 2018 12:41 pm
Price reduced £27,500
InoX
Postby The Libyans » Wed Sep 19, 2018 10:41 pm
Hi Im interested, where are you, looking at your Flickr pictures have you had the body off?
Also "I've has enough"??
The Libyans
Postby InoX » Thu Sep 20, 2018 6:17 am
Hello.
I have not had the body off this one. If there pictures of a body off on the photo stream, theyd be for my other car which is gone. The only work ive done is the work as above.
I meant that im no longer interested in the car and that someone else should enjoy it.
Ive had interest from a foreign buyer who is also interested. The car is based in Chorley.
Thanks for your interest
Dave.
InoX
Postby InoX » Thu Sep 20, 2018 1:23 pm
Sale Pending.
InoX
Postby A Van » Thu Sep 20, 2018 9:49 pm
Nice one mate
Postby LSV » Fri Sep 21, 2018 7:06 am
It will find a new loving home in NL ;)
LSV
VIN #: 0944
Postby Admin-bloke » Fri Sep 21, 2018 7:44 am
Congratulations :D
Postby A Van » Fri Sep 21, 2018 3:31 pm
Congrats!
Postby LSV » Sat Oct 06, 2018 12:54 pm
Now paid in full. Can't wait to get the car to NL and start working during the winter period.
LSV
VIN #: 0944
Users browsing this forum: No registered users and 66 guests
