MEC'S EPIC RESTORATION
Re: MEC'S EPIC RESTORATION
Postby bandit » Sat Oct 27, 2018 5:26 pm
Wow, some scary bits there mec. Alex will do his magic, I rekon you’ve caught that before something bad could have kicked off
Postby mec » Sat Oct 27, 2018 6:28 pm
bandit wrote:Wow, some scary bits there mec. Alex will do his magic, I rekon you’ve caught that before something bad could have kicked off
Think you could be right there mate, fingers crossed :dmcdoors:
Postby gary290 » Sat Oct 27, 2018 9:13 pm
your correct, we get a lot of different cars mostly jap imports here but nothing that "special"(needs)
i do wish you all the best with your rebuild and will be watching evey post
gary290
VIN #: 17005
Postby arranj » Mon Oct 29, 2018 12:44 pm
Delta Delorean wrote:I don't see any reinforcing plates for the LCAs for sale one the website. Does Arran sell them " under the table" ? If they are for sale there is no point making them myself
Yes ;) - https://www.deloreango.com/nl/lower-con ... plate.html
I haven't taken a photo of them yet, but it's a laser cut steel plate - you would need 2.
Postby Dan 6511 » Mon Oct 29, 2018 2:25 pm
These are the plates from the club shop:
Postby mec » Mon Oct 29, 2018 3:28 pm
That picture looks familiar ;)
Postby Delta Delorean » Mon Oct 29, 2018 8:24 pm
Thanks Arran and Dan. Looking good and that wil save me time.
Mec: sorry for taking over your post.
Could you post some more detailed pics from the the frame when you get it home? Great that we can follow your restoration. Keep up the good work!
Delta Delorean
VIN #: 5823
Postby mec » Mon Oct 29, 2018 8:31 pm
I have a few pics to post from Alex as he has already made a start, I will continue to post progress posts as Alex sends me more pics ;)
Postby mec » Fri Nov 02, 2018 1:53 pm
Hi all
A small update for you, the chassis as you know is now at Alex's, he has it all set up and has started work ...
IMG-20181028-WA0012 (Medium).jpg (175.7 KiB) Viewed 3430 times
IMG-20181028-WA0013 (Medium).jpg (171.21 KiB) Viewed 3430 times
IMG-20181028-WA0014 (Medium).jpg (140.14 KiB) Viewed 3430 times
As you can see all of the repair areas have been marked up no matter how big or small, the total is around 70 repairs !
the following pics are the 1st area that has been started, this is under the rear dog bone section (now removed), poor previous repairs have caused a lot of the problems on my chassis, so these are all being removed and done properly.
IMG-20181028-WA0006 (Medium).jpg (209.43 KiB) Viewed 3430 times
IMG-20181028-WA0005 (Medium).jpg (172.43 KiB) Viewed 3430 times
IMG-20181028-WA0004 (Medium).jpg (205.36 KiB) Viewed 3430 times
hopefully more updates from Alex to come over the weekend
I have also been doing a bit of work in the garage, i now have the front wheel bearings removed from the front hubs and also driveshafts disassembled, these are a bit worse for ware, with not a lot of grease in them..
20181101_122457 (Medium).jpg (212.35 KiB) Viewed 3430 times
20181101_122505 (Medium).jpg (190.35 KiB) Viewed 3430 times
So now i have another batch of stuff to go to the blasters/coaters..
20181102_124021 (Medium).jpg (276.08 KiB) Viewed 3430 times
That's all for now folk's :dmcdoors: :dmcdoors:
Postby mec » Wed Nov 07, 2018 10:32 pm
OK I've received a few quite disturbing images from Alex...
this is the big plate that was "welded" on the front underside ..
IMG-20181106-WA0009 (Medium).jpg (173.05 KiB) Viewed 3386 times
IMG-20181106-WA0008 (Medium).jpg (182.13 KiB) Viewed 3386 times
Then the following is what lay beneath or rather what didn't lay beneath...
IMG-20181106-WA0005 (Medium).jpg (180.91 KiB) Viewed 3386 times
IMG-20181106-WA0004 (Medium).jpg (196.15 KiB) Viewed 3386 times
Then the final image below is what happened to the front end after Alex literally lent on it, it was an accident waiting to happen...
IMG-20181106-WA0007 (Medium).jpg (132.25 KiB) Viewed 3386 times
So it turns out all that was holding the front end in the right place was that plate :shock:
I can say that i am Sooooo glad I decided to do a frame off now as i think if it were to be used any more as Julian said on a previous post something very bad would have happened
