Postby gruffalo » Mon Dec 10, 2018 9:57 pm
Crap! #@%@€$¥#¥$&#*@^$&#!!!
Postby mec » Mon Dec 10, 2018 10:59 pm
oooo whats that ??
Postby cis6409 » Mon Dec 10, 2018 11:18 pm
Is that a hole in the rad!?Ouch.. how did That happen?
Postby Spudmurphy » Tue Dec 11, 2018 9:24 am
So much for fitting the "little bleeder" !!!!
Will you get a new style rad?
I will have a spare original rad soon - I have the new one ready to fit in - I'm just using the old one to get the car up n running.
Get a new one - they are supposed to be more efficient?
Postby mec » Tue Dec 11, 2018 10:36 am
Ive got a 3 core ally one in my car, they are very good !
Postby gruffalo » Tue Dec 11, 2018 6:48 pm
In the process of replacing that little hose, I broke the plastic fitting on the radiator. I did add a little bleeder valve, but the hose had to be replaced anyway.
I'll drop the rad pack, it gives me a great opportunity to check the fans too. I can not imagine that they work.
Postby Spudmurphy » Wed Dec 12, 2018 8:31 am
When I removed my hose I used some heat from a hot air gun - it helped - but this is of no use to you now - maybe a useful tip for anybody contemplating removing this hose?
Some wd40 may help a bit too.
Postby mec » Wed Dec 12, 2018 11:54 am
I know this is no use to you now but for others in future if there is enough length in the hose, it may be worth sacrificing the end of it and cut a slit up the side so it relives the pressure off the fitting, once its off then then cut the end off to create a fresh end to re attach later, just a thought
Postby gruffalo » Wed Mar 27, 2019 3:07 pm
Ohhh, more than 3 months of silence here. I got the new rad half way in, replaced a rad bracket and the horns, cleaned all the electric connectors up in the front area and got the recall brackets ready to install. I also got new indicator lights with wiring, and front lowering springs. The latter not installed yet. All parts from DeloreanGo.
The truth is that I spent forever trying to fix my daily driver, and brilliantly failing at it... So I got sick of fixing old cars.
I guess we´re aiming for the 2020 season now, unless something spectacular happens.
Postby A Van » Fri Mar 29, 2019 10:18 pm
Well that’s not that far away !
