VIN 10223 FOR SALE BY AUCTION (est £42k)
Postby DJK73 » Mon Jun 24, 2019 7:14 pm
UPDATE: NOW FOR AUCTION: https://www.coys.co.uk/cars/1981-delorean-dmc-12-3
Reluctant sale but new project looms...
DeLorean DMC12 1981
Flat hood, Grey interior with manual transmission
I Imported this car In 2015 and have since extensively restored the car to a very high standard including the following:
New Euro-spec Volvo higher compression engine rebuilt by Alex Canini including lightened flywheel, ported and polished cylinder heads and port matched inlet manifold.
New bearings, valves, valve guides, seats, and seals, cam shafts and rocker arms, new liners and rings, liners stainless shimmed and bonded. New timing chains and tensioners. New oil pressure sender and pressure switch. Every engine part glass bead blasted and all gaskets replaced. The engine work was circa £6k
Manual Gearbox rebuilt by UN1 specialist GTO Racing- one piece shaft, straight cut lower ratio 1st and second gears
Quaife LSD, gearbox upgrade cost circa £5k
Delorean Go free-flow stainless steel sports exhaust system (new manifold gaskets/studs etc)
Stainless exterior re-brushed by Chris Nicholson (PJ Grady UK)
Roof box repaired and re-bolted
New style DMCH fuel pump
New aluminium billet lower control arms
New DeLorean Go ball joints
DMC Europe control arm support brackets
New front lowering springs
All suspension bushes renewed
Spax shocks all round
New brake flex lines
New clutch line
New clutch
New clutch master
New clutch slave
New brake master
Brake calipers overhauled and stainless pistons fitted
New seat covers (DMCH)
New steering rack
New track rod ends
New wheel bearings all round
New AC compressor, accumulator, evaporator, heater matrix,interior fan, AC all working
New window motors
New toll gate windows
New stainless steel expansion tank
New Club Alternator German (high amp type)
New starter motor
Stainless Alternator tensioner
New Anti roll bar bar bushes
New water pump
New engine mounts
New gearbox mounts
New trailing arm bolts
New inner and outer door rubbers
New PJ Grady door struts
New DMC Europe Aluminium radiator
New silicone coolant hoses all round
New modern low current fans
New illuminated window switches
New fuel Accumulator,
New stainless black coated fuel lines , fuel filter
New injectors
New ignition coil, cap, arm, leads and plugs
New vacuum hoses all round
K&N Air filter
Custom LED door lights
Custom rear 3rd brake light
Reverse camera with screen in rear view mirror
Reversing sensors
DMC Europe convex wing mirrors
Most brackets and parts have been removed and either re-plated or powder coated.
Pioneer sound system with new speakers and wiring, Bluetooth and USB connectivity
Loads more new parts, too much to list...........
The car is quick for a DeLorean and as can be seen extremely well maintained
The interior is in very good condition and original apart from the seat covers, dash is slightly sun-burnt but not cracked and only noticeable in certain light/angle (one of the last jobs to do)
The binnacle has been recovered by Lee Pattison and is in mint condition.
This is one of the nicest and most ‘sorted’ turnkey DeLoreans in the UK, it is held in high regard by the community and probably the fastest non turbo car.
£45K ONO
Serious enquiries only please.
Dbro4
Ex Vin#10223
Grey interior, Manual
Free flow
DJK73
VIN #: 10223
Re: VIN 10223 FOR SALE - £45k
Postby bandit » Mon Jun 24, 2019 8:29 pm
Wow that’s a surprise Dan, what you buying?
Postby DJK73 » Mon Jun 24, 2019 9:15 pm
bandit wrote:Wow that’s a surprise Dan, what you buying?
Haven't made my mind up on that yet youth I've always fancied a turbo esprit or a Datsun 260Z (sucker for shit cars) maybe another D but do it A bit different this time but we will see.
Dbro4
Ex Vin#10223
Free flow
DJK73
VIN #: 10223
Postby mec » Tue Jun 25, 2019 11:38 am
:shock: :shock:
As long as u dont dissapear Dan !
Postby cis6409 » Tue Jun 25, 2019 3:00 pm
That's gonna be a mega sorted car for the person who gets it!.. Gutted to hear you selling it :( it s a credit to ya, I'll never forget that spin at eurotec incredible quickness off the mark with that gearbox and engine work! :o :D
Best of luck with the sale!
Postby mec » Wed Jun 26, 2019 12:53 am
KEEP IT !!!!!!! :dance: :dance: :dmcdoors: :dmcdoors: :dmcdoors: :dmcdoors: :dmcdoors:
Postby Chriss » Wed Jun 26, 2019 10:01 am
Turbo Esprit you say? You have my interest ;)
We talking the early eighties Giugiaro / James Bond For your eyes only Esprit?
Or the Stevens from the late eighties?
Lovely cars but parts supply isn’t quite as ready available as the D, especially if you get a early dry sump! A few good specialists around though who make the parts in their sheds ;)
Good luck with the sale Dan and feel free to ask if you want any Lotus advice, for what it’s worth lol
Postby DJK73 » Wed Jun 26, 2019 10:44 am
Chriss wrote:Turbo Esprit you say? You have my interest ;)
Cheers mate,
The early 80s one of course
Dbro4
Ex Vin#10223
Free flow
DJK73
VIN #: 10223
Postby Chriss » Wed Jun 26, 2019 2:12 pm
Cool, assumed as much.
This Essex Esprit turbo is lovely, and considered as the pick of the bunch as rare as RHS although a few up for sale at big money currently, and this is considered cheap for that particular model, but I believe this one has sat for a while so might well need some money spent on it to bring it up to A1.
https://www.coys.co.uk/cars/1981-lotus-esprit-essex-turbo
IMHO the best Lotus forum worth joining up for advice and infohttps://www.thelotusforums.com/forums/
Nothing as good as DeLorean Go ;) but a few ok vendors http://pnmengineering.com and https://www.sjsportscars.com
And you have got our very own Mr Dunster for parts but he is a bit crap ;) https://www.deroure.com
Postby bandit » Wed Jun 26, 2019 4:40 pm
Has someone bled to death inside that Essex turbo? Wow that red interior is properly offensive.
I know it was the 80’s, but there really is no need
Users browsing this forum: Majestic-12 [Bot] and 3 guests
