Admin-bloke wrote:Good luck with it Ryan, I can't wait to see the motor
Youve seen one, youve seen em all
I cant wait to start enjoying it, then cuss it, then enjoy it a little before i swear at it some more
DeLoryan VIN 5219 - Oct 81 Grey Interior, Manual Grooved Hood Reg: FNP 478W (Finding Numerous Problems) Travelling And Recreation Developed In Style Member of the Beverley Hills Car Club Club
Ive only sworn alot when doing the accumulator and trying to work out what went wrong when i did the fog light the 1st time. Otherwise its been a pleasure really.
Those convex mirrors are great. I can finally see out the side mirrors now. Had to fix the driver side motor as it didnt go through full travel left to right. A bit of contact cleaner sorted that and a bit for the passenger side too for good measure.
If you havent already, you should definitely upgrade to the convex. Theyre fantastic. Before all i could see, if i was lucky, was the rear panel magnified by 100. Now i can see all those smiling faces ive overtaken
Hazard problem is now sorted. A simple upgrade to LEDs and now they work as they should. As mentioned earlier, the right indicator speed was sorted when i upgraded the flasher relay.
Rear lights have now seen new tail light boards and LEDs. So now the whole exterior lights are LED except for the headlights which are H4s and everything is working how it should. Although, the brakes kinda glitch, is that normal? (Probably should have done the video at night).
Ive changed the A/C panel lights to LED but dont know where the cigarette lighter one is. Still, its all much better now. I really didnt like the heat those bulbs generate. They didnt have to be on long before they'd reach the temperature of the sun. Ill be doing the binnacle cluster soon and then the whole interior (except the battery light) will be LED too. I may save that job for october tech as it will give me something to do.
I start a new job monday so can start buying new front lower springs, lower ball joints and the crème de la crème lower control arms. I want to do the whole job in one go so i dont have to take things apart more than once. Then ill move onto getting a condenser, new rad and fans. Itll be an ideal time to include the bleeder kits too.
Its really great seeing the car coming together even if most of it are parts you cant see.
Hazards flashing together like they should whilst the sidelights are on
FINALLY! I now have my V5C "logbook". Im getting the plates made up tomorrow morning and then im off out here there and everywhere. The car will be at the essex mini meet in september.
It took just under 2.5 weeks to register.
Road trips: 2008: Mervyn's Delorean Weekend, Ireland 2008: DMC Europe Open House 2009: DMC Europe Open House 2009: Royal Delorean Weekend, Ireland 2010: Silvercoast, France 2010: Shanefest, Ireland 2010: Luxemburg & Nurburgring 2011: Eurofest, Belfast 2019: International DeLorean Meeting, Hamburg
