Project "Poirot"
Re: Project "Poirot"
Postby hana 5284 » Wed Oct 02, 2019 8:13 am
reminds me of sally bum holes old car without all the sh*t in the foot wells.
well done mec keep the pics coming sorry i missed out on your epic road trip....good times!
tys xx
Postby mec » Wed Oct 02, 2019 1:13 pm
Thanks Dan, yea its mad what people think a "repair" is a ! :snooty:
Tys you are always remembered on all of our road trips :kiss:
Postby bandit » Wed Oct 02, 2019 6:01 pm
Nice work Mike
Postby bandit » Wed Oct 02, 2019 6:19 pm
hana 5284 wrote:reminds me of sally bum holes old car without all the sh*t in the foot wells.
tys xx
Ha ha love it Tys :lol:
Postby mec » Wed Oct 02, 2019 11:48 pm
Thanks Me Julie :kiss:
Another update for you today, I started work on that inner wing repair, here's the before pics...
20190930_214027 (Medium).jpg (169.23 KiB) Viewed 8358 times
20191002_103153 (Medium).jpg (210.29 KiB) Viewed 8358 times
20191002_103202 (Medium).jpg (217.62 KiB) Viewed 8358 times
20191002_103806 (Medium).jpg (259.5 KiB) Viewed 8358 times
So I started off with of all things a bottle jack ! ...
20191002_104052 (Medium).jpg (266.52 KiB) Viewed 8358 times
After alot of Hammering with serveral different panel hammers, dollys and club and sledge hammers too I ended up with this ...
20191002_124757 (Medium).jpg (202.37 KiB) Viewed 8358 times
20191002_155343 (Medium).jpg (266.38 KiB) Viewed 8358 times
I'm well chuffed with how its come out, remember this isn't a flat panel and all those shapes had to be panel beaten back into shape, there is no filler in at all, its all metal, its by no means perfect but its the best i could do, its now had a coat of etch primer and stone chip both sides ready for some stone silver paint which I'm going to get made up tomorrow, here's pics with the stone chip applied...
20191002_223339 (Medium).jpg (272.19 KiB) Viewed 8358 times
20191002_223345 (Medium).jpg (260 KiB) Viewed 8358 times
20191002_223356 (Medium).jpg (149.16 KiB) Viewed 8358 times
20191002_223406 (Medium).jpg (129.17 KiB) Viewed 8358 times
So apart from the stone silver coat of paint, this repair is done, onto my next repair...
The drivers side window on the car doesn't work, this was in the advert so was always on my to do list, so I took the door card off and this is what i found...
20191002_215318 (Medium).jpg (228.42 KiB) Viewed 8358 times
Someone has been here before and attempted to repair the regulator with wait for it ... push bike gear cables !!! ...
20191002_215323 (Medium).jpg (79.91 KiB) Viewed 8358 times
Tape & cable ties ...
20191002_215722 (Medium).jpg (136.43 KiB) Viewed 8358 times
20191002_220826 (Medium).jpg (193.74 KiB) Viewed 8358 times
More bike parts...
20191002_220830 (Medium).jpg (184.32 KiB) Viewed 8358 times
So its safe to say this regulator is going in the bin and a new/2nd hand one will go in once i find one (which i think i have ;) )
So on we go :dance: :dance:
Postby bandit » Thu Oct 03, 2019 8:17 am
Yeh but you’ll have no top gear now :D
Postby mec » Thu Oct 03, 2019 8:37 am
:lol: :lol: :dance: :dance:
Postby mec » Sun Oct 13, 2019 8:39 pm
Hi all
A few updates for you over the last week, i picked up a 2nd hand window regulator to replace the bodged one that was in the car, this was a massive £35 so very good value in my opinion...
20191004_103452 (Medium).jpg (355.51 KiB) Viewed 8265 times
Whilst i was in the door I sorted out door lock too, it didn't work properly, this turned out to be a snapped return spring which was laying on top of the lock, i nicked a coil out of the spring and bent it into a hook shape and reattached it, a nice free fix ..
20191004_110730 (Medium).jpg (263.21 KiB) Viewed 8265 times
Also when i took the door card off it was pretty much in half...
20191006_221831 (Medium).jpg (222.34 KiB) Viewed 8265 times
So this was easily repaired with some oversize washers
20191006_222920 (Medium).jpg (214.53 KiB) Viewed 8265 times
I then cleaned all the black sticky stuff off the inside..
20191006_235931 (Medium).jpg (217.98 KiB) Viewed 8265 times
and put everything back together, the window and lock are now working great, I then turned my attention to the rusty wing, I was just going to replace it, however with this being a budget project I thought Id have a go at repairing it 1st , here's the wing before...
20191008_145539 (Medium).jpg (221.71 KiB) Viewed 8265 times
I cut it back to good metal and started making a panel...
20191008_201637 (Medium).jpg (93.43 KiB) Viewed 8265 times
this then turned into this ...
20191008_213351 (Medium).jpg (241.66 KiB) Viewed 8265 times
20191008_213357 (Medium).jpg (237.43 KiB) Viewed 8265 times
I welded the 1st "curved section" from the back so there would be minimal dressing needed on the front groove
20191008_220156 (Medium).jpg (166.3 KiB) Viewed 8265 times
the other section I welded from the front as this bit is flatter and has to curve in a different way..
20191008_220332 (Medium).jpg (186.12 KiB) Viewed 8265 times
20191009_093411 (Medium).jpg (237.54 KiB) Viewed 8265 times
there was also this hole hiding under the filler..
20191009_095611 (Medium).jpg (194.37 KiB) Viewed 8265 times
I had to weld a plate in from behind as the metal was so thin, there was also a small rust hole a bit further round the arch, this was small enough to weld up ..
20191009_095815 (Medium).jpg (163.69 KiB) Viewed 8265 times
finally this is the wing test fitted back on...
20191009_104734 (Medium).jpg (134.11 KiB) Viewed 8265 times
20191009_104746 (Medium).jpg (206.71 KiB) Viewed 8265 times
Its by no means perfect but a lot better than the previous repair, It bolts into the original holes now as least !
It will require some filler, hopefully this will make the repair look nice and tidy, we will see i guess, this will be the next step. on we go, Hopefully another update coming soon ;)
Postby bandit » Mon Oct 14, 2019 7:35 pm
Top work Mikey boy :thumbsup:
Postby mec » Mon Oct 14, 2019 9:27 pm
Thanks me Julie :kiss:
