1. K111143A Major Service Kit (4 Year 30,000 Miles)
2. K118674 Complete Hose Kit - (they installed only in the motor compartment, the rest I will install myself).
3. 107000 Fuel Pump and Sender Module and tank cleaning
4. 73010 REBUILD A/C MODE CONTROL SWITCH (BENCH JOB)
5. 102462 OIL PRESSURE SENSOR (LIGHT)
6. 100408 REAR SHOCK (PAIR)
7. 102807 REBUILT FUEL DISTRIBUTOR
8. 102353 WARM-UP / CONTROL PRESSURE REGULATOR
9. K102318A BRAIDED STAINLESS FUEL LINES (BLACK - SET OF 9)
10. 100462 CLUTCH MASTER CYLINDER
These parts already here and I will install them::
1. GT100200 Performance Air Intake.
2. 101994 BUSHING, STRG COLUMN
or do I need this: Delrin Steering Column Internal Bushing https://www.deloreango.com/de/steering- ... shing.html
The steering column is moving up/down
Following parts will be ordered from Deloreango.com:
- K111592B Struts Set
- 12x 106272 SCREW, REAR TAIL LAMP
- 2x 111128 The DeLorean Go Silicone Rubber Outer Door Seal (1 COMPLETE DOOR)
- K111096 Decal / Label Set
- Reproduction Wide Dealer Side Stripe with 3D DMC Logo (full set)
- 106931 Stainless Exhaust Heat Shield
…and Delorean.eu:
- 101601 Left Black Headlight Gap Finisher
Brakes
- 109040A 50:50 Brake Master Cylinder
- (2) 109000 Caliper Rebuilt Kit (Front)
- (2) 109006 Caliper Rebuilt Kit (Rear)
- 109005A Front Brake Pads (complete set of 4)
- 109012A Rear Brake Pads (complete set of 4)
- K100095 Front Brake Discs (PAIR)
.......a. or vented for 213 Euro
- 100252 Rear Brake Discs (PAIR)
For the German TÜV I need lights and tyres. The aftermarket lights are cheap at 70 Euro all 4. The Hellas are 4 times more expensive
- Front - 195/60 R14 - easy to find
- Rear - 235/60 R15 - almost impossible?
