7161 Chassis restoration
Re: 7161 Chassis restoration
Postby eric » Thu May 28, 2020 10:36 am
Glad you posted that actually I think I will need to do the lift outside..I was planning on in a shed but I think roof space is too limited judging by home much the lift needs to come up by. Is removing the intake really necessary ? I have seen folk doing it without but the chains on the W pipe did worry me.
Postby mec » Thu May 28, 2020 10:50 am
Do you mean the inlet ? I took mine out without removing anything off the engine, just split it from the box, it came out pretty easily...
20180929_152312 (Medium).jpg (370.18 KiB) Viewed 8622 times
Postby eric » Thu May 28, 2020 11:12 am
Cool, yeahh sorry I dunno why its always ingrained me calling it the head....
Postby eric » Thu May 28, 2020 1:29 pm
Any estimates of the chassis weight ?
I was wondering about putting it on a set of roof bars to save me renting a trailer 3 times. 120 KG is the limit keeping in mind what I have lifted so far I cant see it been that much.
Postby cis6409 » Thu May 28, 2020 2:46 pm
As mec says, no need to remove the intake manifold or anything before lifting. I had mine partially stripped beforehand checking and searching for the head gasket leak...
When I got mine galvanised I think I remember it was circa 95-100kg, some where in that ball park.
Postby eric » Fri May 29, 2020 9:23 am
It begins (spot any issues)?
First lift failed as I had the flaming Leveller on side to side so it would let me jiggle it not tip it.... LOL live and learn.
I popped the W PIPE off as I wasn't happy with the weight getting put on it.
Up she comes
Double check all ok
Tada !
All in all a piece of cake, so much easier with no body to worry about bashing. When the transmission came out it swung a little and brushed the chassis. No biggie but I thought ouch that would have been a rear window gone or scratched stainless if the rest of the car was there.
One of the engine mounts was a bit stubborn whilst been loose it wouldn't release for a while but in the end it came.
I would highly recommend not splitting the transmission it was so much easier and I look forward to putting it back in.
Handful of bits left to remove prior to the dip
Postby mec » Fri May 29, 2020 12:50 pm
Top work mate, Its deffo easier to do everything with the body of, i have no idea on the weight, i used a trailer as youve probably seen in my thread
Postby eric » Mon Jun 01, 2020 7:11 am
With the engine removed, onto the yard for some serious photos, labelling and undoing.
This is the plate welded onto the bottom. One of the main reasons I wanted to tackle the chassis was knowing of its existence.
Fuel tank area doesnt look too bad, just some epoxy coming off but again clearly visible is the fact rust is there and into the epoxy coating. The box section at the back as well so I am so glad I am doing this and not just lashing paint/waxoil on to let it seep further into the frame.
Underneath doesn't look too bad.
Certainly had its share of bumpy lifts in the past.
Transmission assembly coming out. I did think this bit was bent sub normally but looking at the original part it also has a bend on the end.
Loving this nut and bolt hand drilled at the time of manufacture.
Fuel accumulator was fiddly, hats off to anyone who has managed to do this without ramps and poor access.
As you can see the rubber has perished off these hoses fully, methinks I might be adding a new pair to the list.
On the question of galvanising, if I need to re-thread all holes how in gods name would you get in here with such impossible access.
All done.
Fingers crossed off to pro-dip this evening. I did get a set of roof bars which have been load tested to 150KG but I am not chancing it. It feels far too heavy for a roof, maybe if I had the Land Rover going but with it full length rack and spread even load but on 4 single points of roof bars it feels wrong.
At least I can use the Bricks/Wood/Hoist/Leveller for the Landy lift off next year following a similar vein.
I have given Alex the heads up I am hoping by the end of the week/weekend to have it to him and will post more pics. Interesting will be the first pics post pro strip and when he takes the welded panel off.
Postby mec » Mon Jun 01, 2020 10:10 am
Top work mate, it looks pretty solid compared to mine ! lol Alex will be able to sort that no problem :thumbsup: :thumbsup: :thumbsup:
Postby eric » Mon Jun 01, 2020 10:17 am
Thanks Mec, Yeahh that was my thinking as well, but there are so many places where the epoxy has broken down I am still glad I have done it. I think it will need the front frame extension fully replacing and some serious patching there which is a chassis off job anyway I am thinking.
Not to mention the piece of cake element of replacing hoses, shocks etc which is now a synch for what in reality doesn't feel like a whole load of work.
Just the fact I caught the rear trailing arms (loose nuts and bent bolts) makes me so happy, Surprised the MOT didn't pick that up.
I now face the "must make everything shiny" syndrome and can see myself taking springs etc to be blasted and painted.
