Postby A Van » Sat Aug 29, 2020 9:16 pm
It might be worth taking the blanking plate of the timing cover and seeing what state the chains are in.
It’s almost like the car was in a flood? Or exposed to water for a long time but no air to dry it out judging from some photos I have seen.
There is likely all sorts of crud in and around the liners which you can’t get to without a full tear down which based on what I can see is the way I would be approaching it.
Postby Darrenre » Sat Aug 29, 2020 11:14 pm
A Van wrote:It might be worth taking the blanking plate of the timing cover and seeing what state the chains are in.
Could you advise the Correct Way to do that please.
Darrenre
Postby Darrenre » Sat Aug 29, 2020 11:16 pm
DMC1983 wrote:I would get a 35mm ring spanner on the crank pulley. You could use a socket but you would need to remove the muffler to do it that way.
What is that in the 2nd picture?
Will look for a 35mm something. The second picture is one of the bores
Darrenre
Postby DMC1983 » Sat Aug 29, 2020 11:39 pm
Postby DMC1983 » Sun Aug 30, 2020 2:34 am
The arrowed part is the blanking plate that A Van is talking about.
Screenshot_20200830-022358_Xodo Docs.jpg (963.62 KiB) Viewed 10615 times
I would agree with A Van in looking at pulling the whole engine and stripping it down. I would also hazard a guess that the transmission will need the same process :-?
Postby Darrenre » Sun Aug 30, 2020 6:26 am
Thank you. I am expecting to have to pull it all apart. Just getting familiar with the car. Chassis inspection will be the main thing to be done as that will drive the plan of attack
Darrenre
Postby bandit » Sun Aug 30, 2020 7:50 am
There is a bloke somewhere near Hastings that will do it I’ve heard, if you’re struggling.
Postby A Van » Mon Aug 31, 2020 4:40 pm
DMC1983 wrote:It is on the american forum dmctalk. I dont think these ones matter quite so much for now and water will channel out anyway. Its the inner door seal thats probably most important so as long as thats intact, water shouldnt creep in via the door.
Ive driven in torrential rain a couple times now and the car has been fine. My advice is to try and focus more on the bigger things. Its easy to get side tracked on the smaller details.
Myself, this is what i do but if i have trouble with something, i will do a smaller job just to feel that victory feeling. I (like every owner) struggled with the accumulator (its a real bitch of a job), so to feel like I had a win, i changed the gear stick boot.
Basically you have to drill out the old rivets. The garden hose slips over the torsion bar which should protect it if you have a slip. Part of the rivet inside will fall into the door. Apparently it will rattle for same time in an inaccessible part of the door but will eventually work its way out of a drain hole. You then remove the old rubber, glue the new one in place and rivet back on the door. Im looking into sheet screws so if i had to change them again (which isnt likely) then no drilling is required.
Whatever job you do, take your time and dont rush. Its worked very well for me. Anything youre not sure about ask here. Guaranteed we've already done that job and have some tips or tricks, actually even if you're sure sometimes it can pay to ask anyway.
Regarding arran... hes damn quick. Its like you get your order before youve even ordered it. Make a list (there is a wishlist option on the DGo site) and order what you can when you can. Dont expect that list to shorten though. It grows. Just as you think youre making a dent, more gets added. Feels like it will never end.
Here is a picture of arran with all our delorean money :lol: :lol: :lol:
I think Chris M (Rissy) figured out a way to use screws instead of rivets
And knowing him he has probably noted what type etc
Postby Darrenre » Mon Aug 31, 2020 4:51 pm
So another fine bank holiday. Most of the Engine bores are still full Or part full of WD40 (some has run out through an exhaust underneath or into the sump)
Thought I would finish the fuel tank inspection.
Had to drill out all the screws and to be honest I am quite pleased with what I have found With the pump and tank in general, after sinking myself up to my arm pits in stinky varnish!
Here you go
After but I still smell of varnish!
Before gloves and arms
Looks like it works
Nice
All the bits
Under cover
Darrenre
Postby eric » Mon Aug 31, 2020 5:05 pm
All too familiar, a very common sight......
Top job and good work. Get it syphoned out and a load of rags in there to clean it up... But before you go dislocating your elbows for this and other jobs, if you are going the whole hog and lifting the tub off the chassis and engine out, a lot of these jobs suddenly get a lot easier.
How is the Chassis looking ?
