Hello Guys,
I've a Delo since 2016...it is VIN:10036 Texas cars
I've made a fun clock that helps us to troubleshooting the car issues:
The GreenBox is aimed at those who do not want to lose the vintage character of the car, but at the same time want to have a tool that allows him to have under control the most important parameters of the car.
DeLorean Green Box is a device that allows you show on a monitor the parameters of the car and record them onGPStelemetry for in-depth analysis. Every parameter can be recorded on MicroSD.
Externally, the OLED monitor can be positioned in place of the EOM clock and is similar to a liquid crystal clock from the ‘80s, but with a single button it allow to change of the device menu.
info: fabio.siggi@gmail.com
What can display on the monitor:
- DMC Deloreanmotor car logo
- Old style liquid cristal clock with GPS update
- Day of the week, month, year
- Car speed (kmh, mph)
- Altitude, longitude, latitude from GPS
- Ambient temperature (°C, F) and relative humidity
- Frequency valve duty cycle and status
- Lambda sensorvoltage
- Car batteryvoltage
- Cooling water temperature (°C, F)
- Fuel Control pressure (accumulator pressure) (bar, psi)
- Fuel pump current
- Control Pressure Vs Ambient temperature (WUR graph)
- MicroSD datalogger
- Google track on MicroSD (xml format)
You will receive the tested GreenBox. You just need to tap and connect the sensors on the car wiring.
Troubleshooting GreenBox presentation
https://www.youtube.com/watch?v=hix-ooALivg
Meaning of the Duty cycle
https://www.youtube.com/watch?v=4g4K49z_VWE
On me DeLorean for customer test
https://www.youtube.com/watch?v=xWRKdrClQiw
Central consolle adaptor
https://youtu.be/eUZvzZs7cjs
Instructions:
https://dm-eng.weebly.com/uploads/2/8/0 ... ctions.pdf
