7161 Chassis restoration
Re: 7161 Chassis restoration
Postby eric » Wed Dec 30, 2020 11:40 am
Its coming together a lot more now.
I had to remove the gearstick for the 3rd time to get at one of the nuts below it :)
Trailing Arms bolted on and zip tied in place pending the rear wheel assembly.
I have it on these bails of bedding which are in turn on little trolley trucks. Its the best thing I have done with it, I can just pull the Chassis around the shed to get access to where I need to easily. Its made such a difference in trying to jump over it or squeeze around it to get the 13m spanner every time.
Engine mountings back where they belong..
Radiator and first wheel assembly on.
Pipework on the LHS has been a pig to get held in place a its so heavy, a combination of additional zip ties, and brackets helped.
All the underneath piping is now complete with new hoses.
Making sure threads are ok for the remaining stuff.
Even time for a play with the advent calendar
Next up is the spring compression and fitting them which I hate doing as I had no end of issues previously. Once I read the guide from Mike Bosworth it was easier.
Fascinating regarding the changes on the washer config on the upper control arms. The manual is incorrect and should be updated. The DMC explodaview is also misleading.
Best I can see following Mr Gradys post on DMCtalk is
BOLT -- Large Washer -- control arm -- 2 shim washers--Chassis--2shim washers -- Control arm -- Large Washer -- NUT
Postby mec » Wed Dec 30, 2020 3:59 pm
Awesome Work mate well done mate
Postby eric » Wed Dec 30, 2020 4:13 pm
Thanks Mike, I am hopefully over the hump of it.
Finally managed to release the aircon hose from the tub as well (3 months soaking in WD40) so well chuffed with that.
Not sure if you put the strengthening plates for the extensions back on yours, I did but aligning them was a nightmare.
Postby mec » Wed Dec 30, 2020 4:32 pm
I had all mine powdercoated ready to go back on but as you say nothing alligned so I left them off in the end, as Alexs new front end is a lot stronger I didnt mind leaving them off
Postby cis6409 » Wed Dec 30, 2020 5:18 pm
:dance: Brilliant to see, that's loads of progress there well done!. Great idea with the bales on the trolley to!
Keep it up
Postby eric » Tue Jul 13, 2021 10:14 am
Wowzers, I cant believe I haven't posted on this thread in so long.
Rest assured I have been chipping away at it but more of on a back burner until our week off was cancelled so what was to be a nice week by the lakes turned into resto finish week :)
Needless to say after a very hot Friday in which I sweated buckets the engine is back in.. WOOP.
Just some tightening up and checking to do before the big drop :) Well hopefully not too big a drop.
Check out this little fella I found on the outside of our house whilst fixing a door.. literally on the brickwork in the daylight.
Postby jerzybondov » Tue Jul 13, 2021 12:05 pm
Great work Eric!
Postby eric » Tue Jul 13, 2021 12:37 pm
Ta... you may call me batman :)
Postby cis6409 » Tue Jul 13, 2021 3:18 pm
:clap: Big steps forward there, well done
Keep going!
Lovely to see everything going back on and ready :thumbsup:
Postby Darrenre » Tue Jul 13, 2021 10:35 pm
Glad to see such great progress. It won’t be long before the “bat” d mobile is up and running!
Darrenre
