Vin6409 engine rebuild
Re: Vin6409 engine rebuild
Postby Rissy » Fri Dec 03, 2021 2:23 pm
Lovely lovely!
Rissy
May 1981 vin#1458
Grey Wheels
Grooved, flapped Bonnet
Black Leather Interior
Chassis: #1073
Engine: #2839
Main Car(s):
Rissy
VIN #: 01458
Postby dmc4087 » Fri Dec 03, 2021 2:40 pm
Love the chassis colour Shane
Postby bandit » Fri Dec 03, 2021 4:30 pm
That looks great, love that dark grey. All looking great there
Postby jerzybondov » Fri Dec 03, 2021 5:55 pm
Also loving the proper battleship grey!
Postby cis6409 » Fri Dec 03, 2021 8:27 pm
Thanks everyone!, much appreciated :thumbsup:
The ral code for it is 7016 I forgot to mention
Postby cis6409 » Sat Apr 02, 2022 9:13 pm
I eventually found a pic of that tap / socket modification for the rear upper link threaded hole that I mentioned earlier in case it helps anyone..
1/2" 20tpi tap welded to a 9mm socket from a narrow or deep 1/4" socket set.
Postby cis6409 » Sat Apr 02, 2022 9:24 pm
Next on to the rear outboard shafts. My original ones were previously butchered off and were damaged on the machined race surface.
Thankfully arran had some ready to go and sorted me out in double quick Time. Brilliant service as always :thumbsup: :dance:
Gave them a clean, and wire brushed the splines with a dremel very carefully to get it all back to clean metal. Also thread chased all the female threads.
Then a bath of deox c from bilt and hamber - really great stuff non toxic and no chemicals just easts rust and leaves good metal behind. Brilliantly simple science but it works! 8-)
Adding hot water speeds up the process alot
Postby cis6409 » Sat Apr 02, 2022 9:39 pm
Hopefully the paint will give it some degree of protection from the elements
Masked up as best I can
First coat going on
Postby cis6409 » Sat Apr 02, 2022 9:46 pm
3 to 4 coats later and they were done
Postby cis6409 » Sat Apr 02, 2022 9:53 pm
Had some spare paint left over so used it on the engine mounts . Some more Cleaning, degreasing and wire brushing back to bare metal ..
