Manual gearbox and other manual related parts!
Postby Miles » Fri Jul 15, 2022 1:19 pm
If you don’t already know, my auto has divorced itself from the chassis - so I thought now is a good time to finally do the body off and manual swap I’ve been talking about for ages!
So does anyone have a manual gearbox they’d be willing to sell?
Or other parts like the gear lever mechanism?
Thanks!
The Door Whore
Vin #4529
Miles
VIN #: 4529
Re: Manual gearbox and other manual related parts!
Postby jerzybondov » Fri Jul 15, 2022 2:47 pm
Did your auto need some encouragement to manage this Miles?!
Postby Miles » Tue Oct 11, 2022 1:07 pm
So far I’ve collected these parts;
B280E even fire engine (170hp! And I have plans...)
UN1 gearbox from a Renault 25 turbo, this has shorter ratios throughout the range and a shorter final drive, so should be great for acceleration and only about 200rpm higher at 70!
NOS clutch reservoir
Manual gear selector mechanism (missing the lever)
I need to order all the service items, clutch, fork, slave, line and master but I’m not so worried about that as it’s readily available.
I will be after a flywheel though. Anyone know where I can get one of those?
The Door Whore
Vin #4529
Miles
VIN #: 4529
Postby jerzybondov » Wed Oct 12, 2022 12:07 pm
Very nice Miles!
The B280E in theory should be an obvious swap - but my understanding is that the ECU-faffery required to manage the EFI is not so straightforward. Will be very interested to hear how you get on!
Postby Miles » Wed Oct 12, 2022 7:03 pm
I’ve never been a fan of EFI, I could swap the k jet onto it, although performance would suffer. So instead, to simplify and lighten the back end, I will put a set of 3 twin choke Weber down-drafts on it, with a stainless tubular intake and stainless trumpets, along with a few other mods!
The Door Whore
Vin #4529
Miles
VIN #: 4529
Postby A Van » Tue Jan 03, 2023 9:55 pm
Thomas Mcelhone would be the man to speak to, his B280 is fantastic
Users browsing this forum: Google [Bot] and 20 guests
