Postby Bvvarf » Wed Jul 09, 2025 1:40 pm
Fresh as a daisy… well, as fresh as a big chunk of mild steel can be !
Bvvarf
VIN #: 04500,02327
Postby Bvvarf » Wed Jul 09, 2025 8:51 pm
Took a dive into the storage cabinets to gather all the bits needed to reassemble the front and rear suspension.
Ended up with quite a lovely pile of parts… it’s basically automotive LEGO for grown-ups!
Bvvarf
VIN #: 04500,02327
Postby Bvvarf » Wed Jul 09, 2025 9:06 pm
I also realized I completely forgot to document the restoration of the big chunky parts.
A bit blurry, sorry
The parts were blasted, powder coated, and baked in the oven.
I used a little powder coating gun from Electrostatic Magic to apply the powder, and a regular kitchen oven for the baking part.
The longest part is blasting the pieces, and the trickiest bit is hanging them in the oven so they don’t end up with marks.
I built some welded supports for the heavier parts — a bit over-engineered, I’ll admit, but at least they were rock solid.
Bvvarf
VIN #: 04500,02327
Postby cis6409 » Thu Jul 10, 2025 2:10 pm
That is class work love it , they came out very nice indeed !
Postby cis6409 » Thu Jul 10, 2025 2:12 pm
What colour did you go with the chassis?
Did you have much welding/ repairs to it ?
Postby Bvvarf » Thu Jul 10, 2025 7:26 pm
Thanks !
I asked for RAL 7005, it was the closest color in the RAL palette.
The most rusted area was where the fuel tank closing plate sits, with some light surface rust.
The grooves in the sheet metal, which are supposed to let water drain, were clogged with dirt, so water had accumulated there. It was rusty over a few millimetres.
There’s also a tiny bit of rust inside some closed sections of the chassis, but nothing serious.
When I bought the car, I was expecting damaged body panels (wasn’t disappointed!) because of the paint, but the chassis looked solid in the photos. So no surprises on that side (only on that side, actually).
tole fond.png (612.9 KiB) Viewed 63639 times
Bvvarf
VIN #: 04500,02327
Postby BABIS » Wed Jul 16, 2025 2:53 pm
keep an eye on the Avo's red bushings as they have a high failure rate!
BABIS
Postby Rissy » Thu Jul 17, 2025 6:46 am
BABIS wrote:keep an eye on the Avo's red bushings as they have a high failure rate!
Interesting, I've had Avo's on my car on all 4 corners for over 16yrs (only done about 14k miles in that time admittedly), and they've never failed on me.
Rissy
May 1981 vin#1458
Grey Wheels
Grooved, flapped Bonnet
Black Leather Interior
Chassis: #1073
Engine: #2839
Main Car(s):
Rissy
VIN #: 01458
Postby Bvvarf » Thu Jul 17, 2025 1:01 pm
Thanks Babis, I'll order the spax ones as advised !
Bvvarf
VIN #: 04500,02327
Postby Bvvarf » Sun Jul 20, 2025 5:38 pm
Hi,
Fitting the front and rear axle bearings using liquid nitrogen (−196 °C / -320 °F).
Safety first :-)
tank
gaz
Bearings in the Nitrogen
inside
Fits like a glove!
en place
Bvvarf
VIN #: 04500,02327
