HUGE store of parts here NOW in the UK for next day delivery
Postby arranj » Tue Jul 19, 2011 4:42 pm
UPDATED AUGUST 2015
Finally..... I have the great privilege of announcing our official tie-up with DMC Europe and DMC Houston. We now have in stock just over £25,000 (EDIT: £45,000) of parts, right here in the UK, in stock for next day priority delivery.
Thanks to the "DCUK Elders" we now have the biggest parts store in the UK since the factory closed, in partnership with DMC Europe, all items ready and waiting for super fast dispatch.
All available with proper shopping cart links, just click and the parts will be there next day (in most cases). For now though here is the complete list (all are on http://www.deloreanclub.uk/parts.html eventually).
All prices are "plus p+p" in all cases. With bank commission it will work out much cheaper than ordering from Ed direct, if you're in the UK or Ireland.
Hopefully it doesn't need to be said, but by stocking these parts we as a club are in no way "officially endorsing" any of these products, nor is this in any way a commercial enterprise. Ed is taking a huge "risk" by storing this amount of product over here, and we as a club are benefiting by having quick access to all of these parts. Other suppliers are available! The effort involved in storing, administrating, and operating the distribution of these parts is being provided for free by me personally, and the club is taking a very very small commission from the sales of these parts to cover the club's running costs, Paypal processing charges, currency fluctuations, etc. As with all of the club's incomings and outgoings, everything is properly accounted for.
UPDATE 2015: EVERYTHING is now listed on http://www.deloreanclub.uk/parts.html - this is the complete list. Lots sold over the years, lots added, the "shop" is constantly up-to-date with stock levels.
The current stock list, not pretty, just for search purposes;
Water Pump with pulley attached (no back) K102119P
Water Pump Back 1000211
Rubber Suspension Bushing 100154
Fuel Pump Boot 101391
Fuel Pump Cover Seal 106684
Front End Recall Plates Brackets - Stainless (PAIR) 111141
Horn - high note 100466
Horn - low note 100465
Tail Light Boards (PAIR) 101488
Convex Mirror Set (PAIR) 110416C
TABs - Trailing Arm Bolts (PAIR) 106883
Idle Speed ECU 106896
Lambda ECU 101068
Ignition Module ECU 101055
Front Wheel Bearing 100404
Rear Hub Wheel Bearing 100973
Door Top Roof Seal LH 106967
Door Top Roof Seal RH 106968
Steering Rack Boot Kit K109061
Silicone Hose Kit K118674
Water Return Pipe 102482
Aluminium 2 row Radiator 100486
Air Conditioning Condenser 106327
Air Conditioning Pump / Compressor 100746
Starter Motor 101044
Alternator 110101
Brake Master Cylinder 105543
Brake Servo 105542
Clutch Master Cylinder 100462
Clutch Slave Cylinder 100843
Window Lift Switch (optionally illuminated) 101177
Window Lift Switches (PAIR) K101177
CV Axle Boot Kit 100119
Steering Column Bushing 101994
Vent Outlet 100761
Fir Tree Trim Clip for Head Lining SP10671
Fir Tree Trim Clip - Round Hole SP10715
Front Lower Arm Support Kit (PAIR) 105177PP
Upper Exhaust Hanger / Muffler Bracket - Stainless 108200SS
Door Gas Strut (single) 100592
Louvre Gas Strut (single) 108209
Luggage Compartment Gas Strut (single) 105063
Door, Louvre and Luggage Compartment Strut Set K111592
Speedometer Drive Dust Shield 105104
Angle Drive 106130
Lower Speedo Cable 101412
or KIT Speedo drive kit K106130
Rear Brake Discs (PAIR) 100252
Fuel Pickup Hose 106287
Fuel Lower Return Hose 106286
Fuel pump screen 101643
Blower Fan Motor 101273
Headlight Adjusting Screw 101202
Hood / Bonnet Hinges (PAIR) 100570SS
Key Blank 109100
Washer Nozzle / Wiper Arm Jet 100806
Brake Fluid Reservoir 109042
Side Marker Gasket (single) 108138
Side Marker Gasket KIT K108138
Fuse Box Assembly 106913
Front Brake Discs (PAIR) 100095
New Water Bottle (NO CAP) 101944
Wheel Cap (Black) 108738
Wheel Caps KIT - black (PACK OF 4) K108738
Mode Switch Repair Kit K114752
Rubber Pedal Pad with DMC logo 101660
Outer Door Seals Kit (both doors) 111126
Fuel Tank Sender 110555
Parking Brake Handbrake Cable - RH 101964
Parking Brake Handbrake Cable - LH 101965
Lower Front Springs (PAIR) 100413PP
Wheel Lug Nuts (KIT) - Set of 16 K100181
Header Coolant Bottle Cap 101977
Pin Retainer SP10691
Seat Belt Seal Cap Cover 106915
Stainless De Ice Plate / Throttle Cover 109628
Engine Cover Stay Assembly 106363
Spring Tensioner 101204
Removeable CO Plug 102392A
Fan Speed Switch 100755
cooling fans with cover 200004
Fuel Hose - return and feed 106979
Flexible Fuel Hose Line (accumulator) 106997
Cigar Lighter Complete with Illuminated Ring 108288
Dummy Switch 105610
Power Window Motor Kit K110073
Power Window Motor LH 110073
Power Window Motor RH 110072
Door and Ignition Lock Set K110416
Rear Springs (PAIR) 100414PP
or KIT Set of 4 springs 100413P
Thermotime Switch 102125
Intake O-Ring Kit K111171
Injector Seal 102631
Exterior Screw Kit K100791
On Off Switch 111638
On off switch PAIR K111639
Rubber Exhaust Mounting 105148
Door Strap Black (Late) no ring 110308
Door Strap Grey (Late) no ring 110309
Pulley Bearing 105638
Marker Light Socket 106429
Crossgate Cable 101363
Engine Cover Support Buffer RH 108720
Engine Cover Support Buffer LH 108721
Escutcheon 101888
Hot Water Valve 100763
Heater Core 101271
Spring Latch sp10333
Stop Lamp Brake Light Switch 100820
Luggage Net Cargo Net Assembly 101454
Glove Box Light Switch 101629
RH Steering Rack Mounting Bushing 108151
LH Steering Rack Mounting Bushing 105843
Engine Mount Kit K100778
Gearbox Mounting 100901
Mirror Switch Adjuster 105085P
Washer Bottle Reservoir Cap 105954
Anti Roll Bar ARB Bush Kit 108912PU
Anti Roll Bar ARB Front Stabiliser Bush Kit 100774PU
Fuel Tank Fill Hose (used) 101562
Rubbing Strips Kit K114109
RH Valance Bracket (used) 108080
LH Valance Bracket (used) 108081
LH Valance (used) 100703
RH Valance (used) 100704
Number Plate Light Lens Assembly 100438
Tail light harness connectors (PAIR) 101489A
Oil Pressure Sender (gauge) 102763
Rear Defroster Switch 101638
Lip seal (Gearbox) 103049
Fascia Bracket (stainless) 108466
Fuel Pump Boot Support Ring (stainless) 101644
Hood bump stop set 110186SS
Headlight Gap Finisher (stainless) 101602SS
Water Hose 108676
Water Pump Short Hose 102153
Header Tank Water Hose Connection 108679
Gearstick Shift Boot (Stainless Bracket) 100688
Front End Recall Full Kit K109269
Front Brake Hose DOT (SINGLE) 100459
Rear Brake Hose DOT (SINGLE) 100460
DOT Brake Hose KIT (set of 4) K111662
Water Pump Thermostat Housing 102140
Thermostat 102709
Thermostat Seal Gasket 102156
Courtesy Door Switch 108244
Courtesy Door Switch Tip End 108244A
Stainless Coolant Bottle Header Tank 101944SS
Angled Banjo for Fuel Pump 110594
Blending Pad A4000151
Ignition Switch 106679
Radius Arm Bush 106716
Radius Arm Bush PU (PAIR) 106716PU
PU bushing 100154PP
Intake Pipe GT100200
O ring 102146
O ring 102283
Waterpump install kit K111170
Power Brakes Kit 2 B002
Power Brakes Kit 3 B003
oil pan gasket 102102
Automatic gasket 103516
Cat Bypass / Exhaust Test Pipe - Stainless 100419SS
Stainless clip otterstat 108633
brass screw 102391
brass screw 102390
injector clips 102346
cap wiper arm 105658
Pedal pad kit K111660
Accelerator Pedal Cover 108205
Re: HUGE store of parts now in the UK! :) >>>>>>>
Postby hana 5284 » Tue Jul 19, 2011 4:54 pm
WOW thats very impressive arran not only the biggest club in the uk but also the biggest stockest in the uk aswell..... ;)
what a fantastic club we have here.
Postby MikeWard » Tue Jul 19, 2011 4:59 pm
This is great, very impressive. Yet another win for DCUK!
Postby bjbrownie » Tue Jul 19, 2011 5:22 pm
Good work and top result! This has been a long time coming! 8-)
bjbrownie
VIN #: #10556
Postby tourettes tony » Tue Jul 19, 2011 6:52 pm
now that is quality, what more do we need :D
Postby DMCDELLBOY » Tue Jul 19, 2011 7:34 pm
well done guys fantastic just what we need bring it on. :dmcdoors: :dmcdoors: :dmcdoors:
DMCDELLBOY
VIN #: 11075
Postby mnickels » Tue Jul 19, 2011 9:09 pm
Unbelievable! Justification of the last few yit Azza!
Hurry up with
Postby Darren C » Tue Jul 19, 2011 9:24 pm
FANTASTIC!
Well done to all those involved.
Postby RobvdVeer » Tue Jul 19, 2011 10:22 pm
Great jobs fellas, can't wait to see a proper shopping cart on the site.
But seriously, how do these parts and prices compare to DeLorean Europe, for example? It used to be wise for me to go directly through the shop in some case, and in other situations Ed would be cheaper for (especially in shipment time and postage). Are you now becoming part of the DMC franchise or is it just a stock-and-forward service?"
Keep up the good work. You are doing a marvelous job for the DeLorean brand.
Postby arranj » Tue Jul 19, 2011 10:28 pm
Essentially we are a (non commercial) DMC parts franchise - for these parts only. The prices are supposed to be the £ equivalents of Ed's in most cases (a couple of items *might* be cheaper), and these parts will only be supplied to the UK and Ireland. The obvious difference will be shipping time.
Keep the questions coming though - I hope there are more? 8-)
The cart will be not much different to how the Club Parts store is now. Still a main front page as in here: http://www.deloreanclub.co.uk/parts/clubparts.htm - linking to individual pages (on the forum) with an add to cart button - just like this: viewtopic.php?f=66&t=2484
