Postby RobvdVeer » Wed May 11, 2011 10:28 pm
Thanks for the explanation.
What about the upper balljoints? Do they come with a similar problem/shortage/alternative? Maybe a pair of up/down could do the trick (just thinking out of the box here)?
Postby Darren C » Wed May 11, 2011 10:36 pm
Completely different style Rob, and readily available.
Postby A Van » Thu May 12, 2011 10:08 am
Darren, the level of detail in your comparisons really helps!!
Like you say we are halfway there, time to start looking at other British around the same time....Bedford etc
At least we have the right body....it's a very good start, I will investigate the Delphi angle
Postby A Van » Thu May 12, 2011 7:29 pm
Delphi TC170 or FBJ5030
Looks similar, will need to look in greater detail.
Its the 'shaft' we need to get right... (isnt it always :)
Postby Dan 6511 » Thu May 12, 2011 9:37 pm
What about the commer van ones arran found?
Postby Darren C » Thu May 12, 2011 9:40 pm
Cheers Al. :D
Now then to continue the analysis the Lotus joint arrived in the post today.
Here's the vital statistics.
Right then, we knew the body was oversize (Phil has had some machined down and re-knurled) and that the shaft was close.
These are my observations:
Size G on the Lotus joint is 16.5mm, bearing in mind you need to machine a circlip slot of 2mm (size E) that only leaves 0.5mm for size D. Granted it's 0.2mm more than the Specialty T joint, but still a little lean for my liking.
Further; the taper is the same but hey look at the length of the shaft (size L) it's 54mm the longest by far of all the joints I've seen.
Now bearing in mind you need to reduce the overall diameter on these joints and then re-knurl the spline back on and cut the circlip grove, it's a lot of work when the shaft is too long to begin with.
Before I totally disregard this joint as an option I'm going to explain further with a TAPER REFERENCE GAUGE I made this evening in my workshop. :ugeek:
This has been cast around the DMCH joint shaft to be totally accurate to the taper. This is almost as good if not better than cutting a hub in half.
Postby Darren C » Thu May 12, 2011 9:45 pm
Here's how the DMCH OEM Delorean drawing made joint fits in the gauge.
The bottom horizontal line is the datum line from the shoulder of the joint (bottom of your lower arm)
The top line is the end of the taper at the base of the thread.
The distance between these lines is size L in my data.
Postby A Van » Thu May 12, 2011 9:46 pm
Ideal Darren!
I think we need to analyse any similar looking 'vintage' joints from some old British cra..I mean cars.
Arran what was the Commer van ref...trying to stop laughing as I type Commer van...its beyond my wildest dreams!
Postby Darren C » Thu May 12, 2011 9:50 pm
Now lets see how a special T VW joint fits in a delorean.
You can see that puts the datum line up by 4mm. This moves the lower arm 4mm away from the hub. This will effect the castor angle, so if you fit specialty T joints then get the alignment checked afterwards. (albeit it's a small amount)
Also note how much further the shaft protrudes the gauge, in reality the DMCH one is below the surface of where the castle nut fits so you have some room here before washers are needed.
Postby Darren C » Thu May 12, 2011 9:53 pm
Now for the lotus joint.
You can see this is getting worse....
After you've spent the time and effort machining it to fit the arm, just look how far it moves the hub from the lower arm.
It's about 8mm out.
