Cheers Al.
Now then to continue the analysis the Lotus joint arrived in the post today.
Here's the vital statistics.
Right then, we knew the body was oversize (Phil has had some machined down and re-knurled) and that the shaft was close.
These are my observations:
Size G on the Lotus joint is 16.5mm, bearing in mind you need to machine a circlip slot of 2mm (size E) that only leaves 0.5mm for size D. Granted it's 0.2mm more than the Specialty T joint, but still a little lean for my liking.
Further; the taper is the same but hey look at the length of the shaft (size L) it's 54mm the longest by far of all the joints I've seen.
Now bearing in mind you need to reduce the overall diameter on these joints and then re-knurl the spline back on and cut the circlip grove, it's a lot of work when the shaft is too long to begin with.
Before I totally disregard this joint as an option I'm going to explain further with a TAPER REFERENCE GAUGE I made this evening in my workshop.
This has been cast around the DMCH joint shaft to be totally accurate to the taper. This is almost as good if not better than cutting a hub in half.
