Postby Daniel Shane » Fri May 13, 2011 3:55 pm
That was quick.
So what is been made al ? Is it Viva body with chevette shaft ?
Postby A Van » Fri May 13, 2011 4:20 pm
As soon as I got through to the MD we hit it off, he has it appears every balljoint ever made imprinted in his brain, and on a shelf in front of him, whilst I was on phone he called in a machinist to get cracking on them, they just rang up to check we wanted a grease nipple in the spec, which I confirmed we did.
Postby Darren C » Fri May 13, 2011 4:21 pm
Top Secret Dan ;)
Top Work Al, :D
Postby Phil349 » Fri May 13, 2011 6:21 pm
Bloody excellent Al!!
I cant believe how quick they have done that, manufacturing a part to order, even if it may be assembled from on the shelf parts if it is, normally takes much longer than a mornings work!! Looks like youve made a very usefull contact there!
Looking forward to hearing the out come.
And I totally aggree with the comments on the quality of some after market parts, I've always found this with previous cars, they are cheap, but then theres a normally reason for it!
Although I was surprised to read about the issues elise owners have had with the delphi ball joint, delphi lockheed are a quality manufacturer used as oem by some vehicle manufacturers. The actual product quality of the delphi ball joints I have looks good.
Phil349
VIN #: 1128
Postby Phil349 » Fri May 13, 2011 6:25 pm
Admin-bloke wrote:Got to say Kudos to all who are contributing this, especially to OCD Darren for being so thorough in his research.
Well done :D
For my part, I've been glad to help. And I am happy that what I found with the special T joints I bought has after all helped and partly led to a better solution for all.
Top work to all involved!
Phil349
VIN #: 1128
Postby bozzzydmc » Fri May 13, 2011 6:31 pm
Yes .. a great team effort ! .. cant wait to just see what comes in the post :)
Postby Darren C » Fri May 13, 2011 9:21 pm
Admin-bloke wrote:
Darren C wrote:As for effect on the geometry with a lotus joint in the De: your lower arm will hang 8mm further from your hub. This will pull the wheel in towards the centre of the car at the bottom where it meets the road and increase the distance away from the car at the top. ie effect your CAMBER angle in a negative way.
As in increase camber positively by about 10-20 Minutes.
Hmmm... I have to disagree with you jedi master ;)
Although I did get the lower and upper arm back to front in my quote above...so I do excuse you. :oops:
To explain: The lower arm sits at rest when spring tension matches the cars weight. On a De this is almost parallel with the ground. So if you fitted a ball joint such as special T or Lotus you'd still have a parallel arm as the weights have not changed. However you have moved up the top arm by the amount of the overlength. This is normally horizontal or slightly angled upwards when the car is sitting on its wheels. Moving it up will strike an arc that moves the top ball joint closer to the centre of the car. This in turn INCREASES NEGATIVE camber.
As the factory set Camber (non adjustable) is 0 to 1/2 a Degree, it increases the negative, not increases positively Nick.
See picture below
As I said earlier this is only a tiny amount, but enough to throw out the geometry.
Postby Darren C » Sat May 14, 2011 8:48 am
bozzzy wrote:Yes .. a great team effort ! .. cant wait to just see what comes in the post :)
They're here :D
I'll keep you all in suspense until later today when I'll post my findings ;)
Postby A Van » Sat May 14, 2011 9:14 am
They're here :D
Getting butterflies now lol
Postby bozzzydmc » Sat May 14, 2011 9:15 am
You are a tease Barren ! ;)
I can just see you now :)
