Postby Admin-bloke » Sat May 14, 2011 9:46 am
Darren C wrote:
Although I did get the lower and upper arm back to front in my quote above...so I do excuse you. :oops:
No problem Darren :kiss:
Postby Darren C » Sat May 14, 2011 10:31 am
OK The moment we've all been waiting for....
Are you on the edge of your seats?
You should be by now.
ooooooooooooooo its getting exciting.
can't wait can you?
Sorry Bozzy, couldn't resist doing it this way... :lol:
The vital statistics (to the sound of a trumpet fan fare)
Postby Darren C » Sat May 14, 2011 10:33 am
The comparison to DMCH joint side by side
And how it looks by gauge
SPOT ON !!!!!!!!!!!!!!!!!!!!!!!
Postby RobvdVeer » Sat May 14, 2011 10:35 am
Congratulations!! :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup: That is fantastic!
Postby A Van » Sat May 14, 2011 10:38 am
Looks like we have done it!!!!!
Postby Darren C » Sat May 14, 2011 10:44 am
Ok now the serious stuff.
1. No blueing.....I did speak this morning in length with the guy who made these, he laughed when I said the DMCH batch was blue.....softens the metal (we knew that) ;)
2. Also the steel used in these unobtainium joints is a high quality carbon steel VERY HARD.
3. The bottom plate that holds the joint together (has grease nipple in it) is extra thick. Apparently the original DMC joints fail/show wear because this plate bows with the weight of the car pushing down on it. :shock: That opens the gap between cup and ball and you get wear. The Unobtainium joints have a thicker plate to stop this. (discovered through time and knowledge of the product). Unfortunately I think the DMCH joints may follow the original drawing to a T, so have a thin bottom plate.
4.The circlip groove is NOT 2mm as the standard circlip is thinner. With a 2mm wide groove the joint "could" vibrate and wear the spline knurl.
5.The Unobtainium samples have no split pin hole...this is down to choice...the next batch can have them put it. (I plan to drill this out today then trial fit it to my car)
6. With regular greasing the man who made these said it will out last the owner of the car. :D
Ok then....off to fit it now... report to follow. :ugeek:
Postby Admin-bloke » Sat May 14, 2011 11:13 am
Fantastic news there!
Don't forget the pics of them being fitted :D
Postby arranj » Sat May 14, 2011 12:04 pm
Nice one Darren! :thumbsup:
So obviously when replacing any existing ball joint you would just carry over your current circlip and it would be fine? The nut thread matches the original, but not if you're replacing the Special T ones. Does the DCUK joint come with a nut? Nylock?
Postby Chriss » Sat May 14, 2011 12:15 pm
Wow fantastic work guys, made very intresting reading for what is a very critical part. The split pin / castle nut was a later addition as I beleve there had been a few 'issues' with the standard lock nut, so would be worth adding the split pin hole IMHO. I know the joints I fitted to my old car did not have the hole, they were NOS, so I did add the hole.
Another Eurotec club exclusive... I love it when a plan comes together :) :dmcdoors:
1981 DeLorean DMC12 VIN #6328
Postby Dan 6511 » Sat May 14, 2011 12:20 pm
I would be happier using a nyloc nut personally.
